Author Subject: Rich/Lean switching
vernam616
Me again LOL
From previous threads i have made, i have mentioned the way the car smokes weridly
from cold start up it will smoke (as expected), however upon going for a decent run and then leaving the idle it will blow clear, then after 2 mintures of sitting idle it will start blowing smoke again and it smells very rich
A mechanic friend said this is why its smoking, its unburnt fuel and the ECU/Engine doesnt know whether to run rich/lean, hence it blowing clear then back on to smoky again
What sensor is this? ive just bought a CTS sensor and going to try that later, anything else it could be
bearing in mind in the past few months the car has had a new CAT and a brand new bosch lambda sensor
also to note when the car was on diagnostic it showed the coolant temp sensor working ok with it matching the gauge and upon unplugging it dropped to -40 degrees
Audi S3 Black Edition
Posted 20th Nov 2010 at 18:07
midlife
Is the lambda sensor actually plugged inDunno
Cool
Team 330™Cool
Team "no front end or engine"
Posted 20th Nov 2010 at 18:09
vernam616
Cool
Yep , first thing i checked LOL
Posted 20th Nov 2010 at 18:11
midlife
Must be a faulty lambda thenDunno
Cool
Team 330™Cool
Posted 20th Nov 2010 at 18:17
vernam616
Cool
Would you definatly say it was a lambda sensor?
Posted 20th Nov 2010 at 18:18
mabgti
NV motors
If the lambda is permanently faulty.. when car goes closed to open loop it will try the lamda three times at different cycles before it logs fault agen and ignores value.
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 22nd Nov 2010 at 00:19
vernam616
English please mab LOL ?
Posted 22nd Nov 2010 at 18:07
mabgti
NV motors
in other words.. change your lambda!
with a lambda fault idle will run between 11 & 12:1 afr... causing the mist on condensation.
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 22nd Nov 2010 at 20:39
vernam616
Changed the lambda Mab for a bosch unit
Still no difference and still supping juice like theres no tommorow Sad any other suggestions?
Posted 11th Dec 2010 at 01:37
rallyeash
throttle position sensor?
309 3dr K20 Type R
Posted 11th Dec 2010 at 01:44
vernam616
Currently have it disconnected, and this usually increases the fuel consumption
Well it did last time anywayLOL
Posted 11th Dec 2010 at 02:28
plug it back in + ecu re=set.
my engine note changed quite a bit since remembering to plug the lambda back in and re-fitting the cat.
it's using less fuel now Big grin
and sounds evil on WOT Ninja
Posted 11th Dec 2010 at 02:49
cooper666
off topic welshpug just read that argument on . net with you and that guy saying s16 doesnt have a map sensor ive just got to Clapping you Laugh my ass off
*edit* just read your for sale thread saying car is/was superchipped this could be your causing the overfueling problems etc
clio r27
ps3 id:cooperkloe
Posted 11th Dec 2010 at 03:21
