To say its a daily driver, you keep it mint too.
1999 Astor Grey GTi-6 OEM+ (now gone...)2004 Aegean Blue 206 GTi 180 (also gone...)
| Author | Subject: Red Rallye tidy up/underbody protection........ |
matt evans
Seasoned Pro Location: Stourbridge Registered: 16 Sep 2009 Posts: 2,290 Status: Offline |
Post #226
I must say Kev, the power curve on yours (and mine tbh) were some of the smoothest there today, plus yours sounded awesome. To say its a daily driver, you keep it mint too. ________________________________________ 1999 Astor Grey GTi-6 OEM+ (now gone...)2004 Aegean Blue 206 GTi 180 (also gone...) 2006 Skoda Fabia vRS in Sprint Yellow honestly3k wrote: Do you wrestle for a living matt? You sound like a monster ![]() owain wrote: Nothing involving a 306 can be considered worthwhile. |
Post #227
jord294 wrote: matts got a gti 180 ![]() i thought the ka was his Too manly for him a KA Check out the cheeky intercooler on the sleeper rover 200 Best sounding car running up on the rollers by far ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Jake
Regular Location: Durham Registered: 26 Mar 2012 Posts: 251 Status: Offline |
Post #228
Wow! Looks mega clean, lots of work gone into that. ________________________________________ The 205205 GTI6 For Sale Off Racing! |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
Post #229
Kev, was it Millers XFS 5w50 you were using?________________________________________ Cherry Rallye SOLD |
Post #230
Jake wrote: Wow! Looks mega clean, lots of work gone into that. Thanks mik wrote: Kev, was it Millers XFS 5w50 you were using? Yeah Came out pretty clean after 8k miles,never needed to top up,and virtually no oil bar a film in my seperator ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Post #231
The poor old car is on axle stands in bits againTax was up end of Feb so thought SORN it for a month(hopefully) and get the tank down and front subframe to de-rust/paint the remaining underside I did not do when I first bought it Also got a VTS rack to fit Planning on doing the cambelt/water pump while front susp is out of the way too. Once the tank was down I inspected the brake lines and found quite a few patches of rust/corrosion on them So I've ripped all the pipes off,and the compensator and ABS! Will re-pipe it with a single line under car with a bias valve in it then a T piece at rear to each side. Not much rust to report thankfully just the odd bit of surface rust on spot welded areas etc![]() ![]() ![]() ![]() ![]() ![]() ![]() ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Post #232
Had a surprise when I unbolted the upper subframe mount,water ran out of the hole!Would explain the state of these,proper water trap ![]() Nearly forgot I'm refurbing a pair of front hubs too At the beginning: ![]() Degreased and wire brushed,then into the DEOX C :![]() Out of the DEOX C,rinsed,wire brush in the drill then wiped over with Metal Blast: ![]() Looking good,totally rust free now ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
marco gti6
Seasoned Pro Location: Troisvierges Registered: 09 Mar 2009 Posts: 1,350 Status: Offline |
Post #233
Coskev may i ask where you got your downpipe from and what cat you are using? Is it 2,5" if so would you mind telling how much that one cost you?Thanks in advance, Marco |
rich306
Seasoned Pro Location: Portsmouth Registered: 09 Aug 2009 Posts: 1,834 Status: Offline |
Post #234
Damn, a job done properly ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
matt evans
Post #235
Bufty boy phase three!Good work gramps, be lovely when its done i'm sure. You going down the powdercoated route for the subframe? You know the little cups that bolt to the front rails, that were full of water, they are actually two pieces, the cup and the square headed section, they just rust solid together. Give them a clout with a hammer and they'll come apart to be soaked in the deox. ________________________________________ 1999 Astor Grey GTi-6 OEM+ (now gone...)2004 Aegean Blue 206 GTi 180 (also gone...) 2006 Skoda Fabia vRS in Sprint Yellow honestly3k wrote: Do you wrestle for a living matt? You sound like a monster ![]() owain wrote: Nothing involving a 306 can be considered worthwhile. |
russbez
Post #236
ah awesome workalways tempted to take fuel tank off and derust under there same with subframe, think its the only two bits that havent been off my car for a good derust ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez
Post #237
ahhh man why did i see this, i know fine well my subframe cups will be like that ![]() ocd ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
Post #238
CheersRaining this morn ,didn't consider the weather when I started stripping it outside!!!! marco gti6 wrote: Coskev may i ask where you got your downpipe from and what cat you are using? Is it 2,5" if so would you mind telling how much that one cost you? Thanks in advance, Marco It's a universal 200 cell sports cat off E-Bay welded into a Magnex de-cat pipe ![]() Pretty sure Magnec de-cat pipe is 2.5. Cat was circa £100. matt evans wrote: Bufty boy phase three! Good work gramps, be lovely when its done i'm sure. You going down the powdercoated route for the subframe? You know the little cups that bolt to the front rails, that were full of water, they are actually two pieces, the cup and the square headed section, they just rust solid together. Give them a clout with a hammer and they'll come apart to be soaked in the deox. Ah right cheers!They are well stuck together atm Yeah satin black subframe ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
Post #239
![]() Whose is the 220 turbo? Dedication there mate, dedication. ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
matt evans
Post #240
Its some young lad from the local car club. Right heap it is, got a 620ti engine/box in it, we were just waiting for the thing to grenande on the rollers, alas it didnt, but it was boost cutting at 14psi, with an enormous backfire!________________________________________ 1999 Astor Grey GTi-6 OEM+ (now gone...)2004 Aegean Blue 206 GTi 180 (also gone...) 2006 Skoda Fabia vRS in Sprint Yellow honestly3k wrote: Do you wrestle for a living matt? You sound like a monster ![]() owain wrote: Nothing involving a 306 can be considered worthwhile. |
tvrfan007
Post #241
Typical converted bubble then by the sounds of it. Most 'young lads' made them as they could convert a 214Si or similar to a 220 Turbo with ease without telling the insurance. Still running his standard ecu then with the bleed valve replaced with a maxed out bleed valve. Surprised he hasn't just added a motobuild tuning chip innit. even with the boost cut removed mems extrapolates fuelling curves beyond 14Psi anyway, your engine survives solely on the fact it ran rich to start with.The engines are bulletproof on mems to be honest, especially with FMIC he's pretty safe at 14. ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
russbez
Post #242
let us know how easy it was refitting the subframetake it there is no risk of fitting it squint or anything? i bought a few bits from Pug to replace rusty cups and bolts a while back, i never done it cause i new it would be a fair amount of prep work before i put it back together ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
Post #243
russbez wrote: take it there is no risk of fitting it squint or anything? There are pointy plastic inserts on the subframe to line it up Matt will be able to confirm if they do work!!! ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
mik
Post #244
I bought new pointy plastic bits, cups and bolts new from Pug and scratched them up, Electrox and then silver paint (except plastic of course!). Sprayed Dynax UC on them once back together. My new subframe was etch primed (B-H Etchweld) then satin black painted, with Dynax S50 cavity wax sprayed inside. Haven't got fuel tank off yet though. ________________________________________ Cherry Rallye SOLD |
matt evans
Post #245
Mine went straight back up, no worries. ________________________________________ 1999 Astor Grey GTi-6 OEM+ (now gone...)2004 Aegean Blue 206 GTi 180 (also gone...) 2006 Skoda Fabia vRS in Sprint Yellow honestly3k wrote: Do you wrestle for a living matt? You sound like a monster ![]() owain wrote: Nothing involving a 306 can be considered worthwhile. |
Post #246
Was hoping to get a good few hours in today and finish off removing the underseal and surface rust ready to paint but woke up to find this:![]() So looking like the Rallye might be off the road for two months rather than my planned one month ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
mik
Post #247
I know what you mean. The other day I had the genius idea to shoot the lacquer onto my C5 wheels before I went to work as it was near ideal outdoor spraying weather - i.e. not raining or windy. Good job I did as it was raining when I got home and hasn't stopped raining since. And I can't do it in the garage because the slightly disassembled car is in there. And I don't think my wife would like a partially lacquered kitchen floor. ________________________________________ Cherry Rallye SOLD |
Post #248
Another day off and nothing done I'm pretty keen when it comes to getting under the car to do some work,but this weather is taking the p**s Not a sniff of getting anything done. The eagle eyed of you 306 experts might spot something I've cut off the car after hitting my head on them too many times!!! ![]() ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Post #249
Hope you don't sell the car to Hovis in the future. He'll have nowhere to put the axle stands ![]() ________________________________________ ![]() |
Post #250
dangti6 wrote: Hope you don't sell the car to Hovis in the future. He'll have nowhere to put the axle stands ![]() That's another reason for cutting them off! To stop numptys putting axle stands under them And they hold water and had surface rust all around them ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
