any pics of how the seal fits would be appreciated.
| Author | Subject: ARB Seals |
richharmer6
Newbie Location: Dorking Registered: 22 Oct 2010 Posts: 6 Status: Offline |
I have just pressed a new set of trailing arm shafts in, can anyone tell me what the clearance gap for the arb seal is. Or if they if there should be one at all? the trailing arm shaft has pressed in so it is flush with the outside edge of the trailing arm.any pics of how the seal fits would be appreciated. Cheers Rich |
trailing arm should be inset by 2mm, and the ARB end plate should be 0.5mm clear each side.to set the clearance to the end plate place a 1mm feeler blade on one side and draw the end plate on fully (the seal on the other side will compress till the end plate is touching) ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
richharmer6
Is the 2 mm gap for the seal to sit in.?? |
yeah, that should have said "trailing arm SHAFT" should be inset by 2mm.![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
richharmer6
Is this what you mean?? richharmer6 has attached the following image: |
yup.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
