displaying posts 126 to 150 of 212
Pages (9): first .. 5 [6] 7 .. last
Author Subject: Denis's Rallye
Denis
Post #126
The springs are 2.5” and as it is two springs - they come down a long way down the strut. So with 15x7 ET15 wheels – I have to run 15mm spacers to comfortably fit the wheels. (This is also the reason that I had to take off my negative camber hubs – the wheels where much closer the struts).
It is not ideal to run with ET0 as it increases scrub radius and the car is prone to tracking the road.
The right solution would be to run 406 hubs (the dimension of the flange to strut is 15mm larger) and longer wishbones (at the same time could lengthen the balljoint and improve the angle of the whishbones!). But also would need longer driveshafts.
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 28th Jun 2011 at 03:35
Post #127
Thanks Dennis. Sounds like a lot of extra work and expense though, I think I'll forget about helper springs and just get shorter main springs for now. I've got brand new drive shafts and neg camber hubs so I can't face the prospect of getting rid of them and starting over.
Posted 28th Jun 2011 at 03:43
Denis
Post #128
Will have a chat with you in the near future about the tender progressive springs as that might be the answer to my Volvo ride quality problems. Its having different springs today (longer 400s) so hope that will sort it out. I've been thinking for some time that smaller progressives with a stronger main spring might be the way forward, but bit looked into it.
When you run two springs, one on top of the other, this is the same as having two resistors in parallel. So that overall spring rate is lower than smallest.
So with my 250-550lb tender progressive and 650lb main springs the overall rate starts with 180lb when the front wheels start to touch the ground. Goes to about 270lb with the car on the ground, then it is 300lb when the tender progressive closes and the spring rate goes to 650lb.
What it means in practice is that you get very low spring rate when driving in a straight line. Once you turn in to a corner and weight transfer happens – the outside of the car rides on very stiff spring which resists the roll. As a bonus, as the other side gets unloaded – there spring gets softer and it pushes up less = still less body roll!
WhiteBMW M140i
Posted 28th Jun 2011 at 04:23
Post #129
Sounds very interesting indeed. I guess it helps a lot having the 3-ways to control the springs. Would my singles cope or would I end up with too much damping for most bumps and possibly not enough later on in the travel?
Posted 28th Jun 2011 at 14:20
Denis
Post #130
Single adjustable are fine – that is what I had on my car for the past year. I felt that the spring rates were very good and kept the same springs when upgrading to 3-ways.
Have a look at Eibach ERS for more info.
WhiteBMW M140i
Posted 28th Jun 2011 at 23:57
Denis
Post #131
From Thursday:
Short clip: video
WhiteBMW M140i
Posted 9th Mar 2020 at 20:33
cosmic spanner
Moral objector
Post #132
russian guy wrote:
Short clip: video
Superman it must be embarrassing being in something so impractical and uncomfortable as a caterfield.. and being unable to catch an old french hatchback in front, who for all you know is listening to the radio! LOL
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 13th Aug 2011 at 20:01
jimmy_boy
Post #133
cosmic spanner wrote:
russian guy wrote:
Short clip: video
.. and here's you waffling on about P6000's hahaha! (Uploaded by the same caterfield guy)
CLICK
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 14th Aug 2011 at 17:52
cosmic spanner
Moral objector
Post #134
russian guy wrote:
Short clip: video
CLICK
LOL I should be careful what I say in future! Doh
Posted 14th Aug 2011 at 18:19
Denis
Post #135
Details of the plates that I made for Safety Devices 6-point cage. The Idea was to spread the load out as much as possible and try to tie in to the structural part of the car, as the floor under the cage feet is very weak. The welding was done by a company called Fabricage, near Cambridge (they specialise in manufacturing and installing custom roll cages).
The rear plates shaped to the profile of the wings.
Extra mount for the a-pillar
Extra mounts for the b-pillar using the seatbelt fixings
As the sun-visors can�t be used with the cage, made some brackets to keep them
WhiteBMW M140i
Posted 9th Mar 2020 at 20:57
Denis
Post #136
Made some seat subframes to re-use existing standard fixings and lower the seats as much as possible. Not to mention that the driver�s seat is perfectly in-line with the steering wheel (which most people do not think about when fitting bucket seats).
WhiteBMW M140i
Posted 9th Mar 2020 at 20:58
Denis
Post #137
Home-made induction kit. RS engine seems to respond very well to long inlet, so I�ve moved the filter as far away as possible from the throttle body. Rolling road showed some nice results...
WhiteBMW M140i
Posted 9th Mar 2020 at 20:59
Denis
Post #138
Who cares how the inlet manifold looks on the outside? It is the inside that counts. So cut it open, smooth and polish all the runners and trumpets. Seat dyno says that the engine breathes better at the top end.
Polishing the insides
Welded back up
WhiteBMW M140i
Posted 9th Mar 2020 at 21:00
Denis
Post #139
Design of some new top mounts for 2 deg of extra castor and adjustable camber 1 to 4 deg.
Wooden prototype
Freshly made
Plate fitted to the car and metal cut away to give clearance for 3deg of camber (no need to cut anything for 1deg, but anything else needs a bit grinding away)
Finished item set to 2deg
WhiteBMW M140i
Posted 9th Mar 2020 at 21:02
Denis
Post #140
Brake disks cracked from multiple heat-cycles
WhiteBMW M140i
Posted 9th Mar 2020 at 21:03
jeffers Forum Admin
Post #141
Denis, them front topmounts are a work of art! How much did they cost to have made in the end? Unsure
Team Running Engine again!
Team Negative Camber!
Posted 11th Mar 2012 at 22:57
Denis
Post #142
They cost quite a bit as 10 sets had to be made to make it economically viable to produce CAD drawings etc. I am just in the process of finalising the list of fittings and getting some prices for a batch of bearings. Once this is all done – will know the final price.
The first set is behaving well on my car. It is surprising how much heavier the steering is with the extra castor!
WhiteBMW M140i
Posted 11th Mar 2012 at 23:10
jeffers Forum Admin
Post #143
I may be interested obviously price depending, you got anything booked for the near future? Oh and have you seen the thread on a forum trackday? Just thought you may be interested! Thumbs up
Posted 11th Mar 2012 at 23:15
Post #144
Feckin' loads, I feel like Popeye trying to park mine LOL
Posted 11th Mar 2012 at 23:31
Post #145
'ello sailor... Wink
Posted 12th Mar 2012 at 08:41
Post #146
Good effort on putting the pictures of the cage plates up Thumbs up
I have got a SD cage, so good to know the best way to mount it.
Car is looking great as always Smile
Posted 12th Mar 2012 at 10:11
Denis
Post #147
Thanks Lee, have seen the thread and planning to come Cheers
WhiteBMW M140i
Posted 22nd Mar 2012 at 22:24
Denis
Post #148
I had chance to run the car at Snetterton yesterday, so put the top mounts through further tests. The conclusion is that the extra camber has improved the grip in low-speed corners. Also they seems to cope without any issues if you take a bit too much curb Superman
Still getting all the bits to assemble the mounts and will have the pricing shortly.
WhiteBMW M140i
Posted 9th Mar 2020 at 21:11
rallye1999
Post #149
What's that on the roof
Posted 22nd Mar 2012 at 22:34
Denis
Post #150
LOL Everyone was asking me two questions on the day: what is under the bonnet (the right answer is BAD dampers) and what is this box on the roof (that would be some RF equipment, can’t say more)?!
WhiteBMW M140i
Posted 22nd Mar 2012 at 22:39
