Author Subject: airbag wires on steering wheel
sqweeky84
on my 306 its got a aftermarket steering wheel, i had to remove it the other day and ive noticed that the wires for the air bag connecter have broken away!! im going to solder wires back on but i dont know witch way they ment to go,
DOES ANYONE KNOW WITCH WAY THEY GO??
OR GOT A PIC OF WHAT IT LOOKS LIKE??
Posted 27th Nov 2010 at 04:48
I had exactly the same issue when I got excited with mine, general consensus seemed to be that it probably didn't matter, but I ended up doing away with the airbag before I found the actual answer.
Annoyingly all the Peugeot online documentation is done in line diagrams, so can't even see on there.
If you've got an aftermarket wheel, do you need the airbag connector anyway?
Posted 27th Nov 2010 at 16:32
sqweeky84
true! don't really need them, but just would prefer them back on, wozen't sure wether it would cause a short or not??
Posted 28th Nov 2010 at 03:09
At what end have they come off? Did they come off in the same place as mine in that picture?
However they've come off you'll have an airbag warning light on as the airbag isn't present. Anything that looks like it might short out it's always worth wrapping in insulation tape do it doesn't.
Posted 28th Nov 2010 at 15:16
sqweeky84
yes the same place as yours have, seen sum on ebay so may just buy one of there
Posted 28th Nov 2010 at 17:23
russbez
had a stab at looking this last night.
Iv also cut my wires when I installed my aftermarket wheel
couldn’t get these resistors to do jack shit
Have not check passenger seat connection right enough.
My wiring stops at the steering column. Could I just put the resistor there instead of having to have said swirly switch wired up with a resistor on it?
p.s i have no airbags in my car, this new "law" is shite, although i will manage to get Rallye through Mot before march. My estate 306 in October will have same problem with light not coming on and going off.
My Rallye project thread
Posted 26th Jan 2012 at 16:26
russbez
managed to sort my airbag light
was my passenger side
used 1.8 ohm resistors
owain ; sorry couldnt see where wires went to that switch actully cracked mine trying to remove a black clip trying to take pictures of wires.
anyways my resistor is pluged ito a small brown plug as i no longer have airbag
it turned out to be the passenger side tensioner wiring that was duff.... put a resistor in there too and airbag lights now behaving its self
Posted 26th Jan 2012 at 19:40
No worries mate, ditched it and took out the bulb some time ago Thumbs up
Posted 26th Jan 2012 at 19:41
russbez
or get one from scrappy? pretty sure this is my second one as i destroyed my first one when i put aftermarket wheel on
only use it for putting indicators off
Posted 26th Jan 2012 at 19:45
