TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!ps3 online name : butcherboy200
dyno print out : 185.4 at the flywheel
modern warfare 2
| Author | Subject: outside tempeture clock |
Paddy Power Turbo
Banned!Location: galway/ireland Registered: 24 Feb 2009 Posts: 628 Status: Offline |
is it possible 2 switch a working temp clock from a 6 to a rallye where is the sensor located________________________________________ TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!ps3 online name : butcherboy200 dyno print out : 185.4 at the flywheel modern warfare 2 |
cooper666
Senior User Location: doncaster Registered: 27 Nov 2009 Posts: 778 Status: Offline |
the sensor is located on the underside of the passanger mirror.________________________________________ clio r27ps3 id:cooperkloe |
Paddy Power Turbo
ok thanks but are they on the rallye ? or do i need to fit 1________________________________________ TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!ps3 online name : butcherboy200 dyno print out : 185.4 at the flywheel modern warfare 2 |
jord294
i'm no expert, but as your rallye will have manual mirrors, you'll have no electrics to them, like on the gti6s i'm not 100% but i think the sensor must need some sort of power so you can then get a display in the dash *edit* if anyone does know for sure, feel free to correct me ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
