Author Subject: a/c switch not working fan
diablowgti6
looking for some advice before i fix this properly (haha)..
have been using the a/c switch to control my fan for a while, problem i have is its no longer working. The fan itself still works and the a/c button seems ok (light still works).
any ideas?
oh s*it built on a thursday
My other cars an 8v turbo
Posted 8th Jan 2011 at 03:33
diablowgti6
30 views and no replys.. Off too a good start here
Posted 9th Jan 2011 at 00:46
Rich E Forum Admin
A/C gas has probably leaked out.
Unless you mean you've disconnected the pressure switch already in which case it will be some sort of electrical issue.
Posted 9th Jan 2011 at 01:01
diablowgti6
yip gas long gone.. my problem is i was using the a/c button to work the engine cooling fan, and for some reason it no longer works (yet if i pull the brown relay under bonnet the fan kicks in) the only other issue i had was the blower motor also stopped working, but i stripped and cleaned that and its ok now Whistle
thanks for reply
Posted 9th Jan 2011 at 04:57
Rich E Forum Admin
Sounds like it may be an issue with the low / high speed fan switching.
Check the relays in the fan housing and go from there.
Posted 9th Jan 2011 at 05:10
diablowgti6
i dont think you know what i mean with this Unsure
nothing has changed with regards to what fan works.. i bridged the(correct)pins on the air con plug to use a/c switch for fan...
problem now is its not working the fan anymore, but the fan still works if i pull the brown plug??
Huh?
Posted 10th Jan 2011 at 01:06
diablowgti6
anyone? Unsure
Posted 10th Jan 2011 at 20:10
Rich E Forum Admin
Okay, when you pull the brown plug do you get both fans running together, both at low speed for a few seconds and then both switching to high speed?
Posted 10th Jan 2011 at 20:11
diablowgti6
i get one fan high speed only (been like this since i bought the car).. but when i use the a/c switch to control the fan the same fan does not work
Posted 10th Jan 2011 at 20:19
Rich E Forum Admin
I suspected that might be the case. Your fans do not operate correctly. That's definitely part (if not all) of the problem. Both fans should run together, either both at low speed or both at high speed.
The three relays in the fan cowling control the switching of the fans and high/low speed. I suspect the root cause of your problem is in there.
Cooling fan system FAQ & circuit diagrams
Start by putting 12v directly across the non-responsive fan to check for a dead motor. Then start looking at the relays.
Posted 10th Jan 2011 at 20:35
diablowgti6
i had the bumper off last week to check wiring/connections etc. While the bumper was off i swapped the two relays (behind bumper) and still only had the same fan work.. sorry to go on and on, but my issue is when i bought the car the fans werent working, so i bridged the a/c plug to control the one working fan with the a/c button. (as many other people have) but now the a/c button wont work the fan (but the fan is still working) Crazy
Posted 10th Jan 2011 at 20:48
Rich E Forum Admin
Get the fans working properly first then look at the A/C switch.
I suspect that once the fans are working correctly the switch will work again.
Posted 10th Jan 2011 at 20:50
diablowgti6
think i know what you mean now, if i get a new changeover relay the fans should work as normal(then i can sort the air con) Cool
thanks mate
Posted 10th Jan 2011 at 20:51
parkerpug
hey did ya fix ya fans??
Posted 17th Jan 2011 at 17:40
