Author Subject: ECU reset
speedo306
Hey fellas,
Would like to know how to reset an ECU? and anything I should not do when resetting.Dry
RJ
Posted 16th Jan 2011 at 07:08
midlife
Disconnect the battery for 10 minutes, reconnect it & your doneThumbs up
Cool
Team 330™Cool
Team "no front end or engine"
Posted 16th Jan 2011 at 07:23
Rich E Forum Admin
No need to disconnect the battery - just unplug the ECU.
Does exactly the same and doesn't loose the time on the clock and stereo settings.
The only useful thing an ECU reset does is to reset the ICV to its home position though.
Posted 16th Jan 2011 at 08:08
speedo306
ok Thumbs up
RJ
1.6306
also what i found when i reset my pug the other night is when i reconnected the baterry the alarm kept going of. when you reconnect the battery put the key in the ignition on the setting before the one to crank the engine the reconnect the baterry, apparently the ecu looks for the imobliser chip with the code in it
Posted 18th Jan 2011 at 05:46
