Author Subject: Lack of power
adonmall
Gave the GTI a service the other day, plugs, oil and air filter. Afterwards it seemed down on power. It doesn't want to pull as normal. I didn't know whether changing the plugs could effect the coil packs in anyway? Plugs are set at 0.8 mil and are Bosch.
I scratched my head for a couple of days then took it to Pug for a check. No faults except they said it's running cool, under 80c. It's always run cool but I've never had this problem before.
Would a new thermostat sort it, as if it's cool too much fuel is being washed over the plugs as it's not up to temperature?
Posted 27th Jan 2011 at 00:04
swiftyboi006
Is the car running 80c even after giving it time to heat up?
Black p3 Love
Posted 29th Jan 2011 at 16:15
adonmall
It run's at about 70c even when fully warmed up. I'm going to throw a new thermostat on it today to see if it makes a difference.
Posted 31st Jan 2011 at 21:02
cooper666
has it got a nissens ally rad on it if it has its normal to run cooler than std
clio r27
ps3 id:cooperkloe
Posted 31st Jan 2011 at 23:36
What air filter is in it? Proper genuine Peugeot? Is it running cool on the gauge or in reality?
Posted 1st Feb 2011 at 00:17
jägertom
I've got something very slightly similar - mine runs are normal temps (80-90c)but i just fitted bosch super plus plugs (the ones with the 4 electrodes). Now it seems to runs smoother at low revs but doesn't pull quite as hard in the high rev range?
Does this sound like what you've got?Crazy
Feelin so fly like a Gti6 Ninja
Team >160,000mi Sad
Posted 1st Feb 2011 at 00:53
pugs16
i had these fitted in my s16, didnt like them at all, car was lumpy and gutless, after about 200 miles i changed them back to normaly single electrode's and was 100% better imo
Posted 1st Feb 2011 at 02:12
Sounds like a thermostat issue to me for the cooling, get a new one in there ASAP. As for the lack of power, did you put in the correct heat rating of plug??
Stan.
Posted 1st Feb 2011 at 13:04
adonmall
I've put a new thermostat on it, no difference. When I changed the plugs originally I put a set of Denso's in it, I've used them before with no probs, but these were iridium.
Could fitting the wrong plugs knacker the coil packs? I've got Bosch in the car now and there's no fault code for a broken coil pack.
I had a look online and faulty coil packs can result in a loss of power?
Is it worth a go replacing them?
Posted 1st Feb 2011 at 18:23
mechanical_repairs
If a coil pack was at fault it would run rough and lumpy and the exhaust would rattle and shake around.
Carl
Posted 1st Feb 2011 at 18:28
adonmall
Cheers Carl,
I changed the air filter too, maybe that's upset the mass airflow sensor?
Where is that on the air system?
Posted 1st Feb 2011 at 19:08
mechanical_repairs
adonmall wrote:
Cheers Carl,
These cars do not run an aiir flow metre, it's all a throttle body with stepper motor etc.
Carl
Posted 2nd Feb 2011 at 01:34
mattgti6phase2
I have run super 4s for years and have never had any problems. I now have a set in my 6 and it's nearly a year ago I fitted them and no problems what so ever.
Are they done up tight enough? To loose and you will get a tapping noise and Im guessing a slight loss of compression where there could be a small gap.
As said just a guess but worth a check. Good luck
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 2nd Feb 2011 at 04:09
