Author Subject: Guide: Cyclone Refurbishment
ash 306
Ive decided to make a guide on cyclone refurbishment with the help of other guides and people to create the only guide you will ever need to refurbish a set of alloys. Enjoy!
PREP!
Firstly, choose a suitable workplace. Luckly, ive not long finished my workshop (no electric yet as ive not got that far up garden yet. Cleaned the workbench.
Before:
After:
Now i have a clean and tidy workplace, we can carry on.
Here are the wheels when i just bought them:
I then had tires removed (you can leave tires on, but its easier and a better job with them off). The tires wasnt that good so i had them taken off and binned. You can sometimes have this done free like i did as its a family member. Here they are waiting to be taken to garage for removal.
Tires now removed, lets get started.
Start off with taking the balancing weights off, i had stick-on and clip-on ones. Just use a flat-blade screwdriver and carefully remove the weights and use some sticky stuff remover to remove the foam sticky pad left when stick-on weights are taken off.
Give them a good clean with soap and water to get the main dirt and oil off.
Let them air dry or wipe down with a cloth.
Now the sanding comes in.
[u][b]
RUBBING DOWN[/b][/u]
A) Using P80 grit paper, rub the bubbling and curbing out!*
A*) If there is any extremely deep kurbing use a small amount of ALLOY FILLER (filler to hardner ratio is approx 1 golf ball of filler to a pea of hardner) However, i used Alloy Wheel Putty so all you had to do is tear a bit off and knead it a little then stick to the wheel. Its brilliant stuff and when dry, its solid and sticks like s*it to a blanket. Also, ive got electric in there now.
Cool Using P120 grit, rub any area touched with the P80 and filler!
C) Start to feather out the wheel with P240 grit where you have sanded the bubbling and curbing away, also the filler. You will see the layers of old paint and primer, kind of like tree rings! All the old layers need to be sanded back until the rings are a decent distance apart and fade into one another otherwise you will see them through the new paint!
D) Continue to rub down with P240 grit any area you touched with the P120 grit!
E) Using P320 grit, rub any area you touched with the P240 grit!
It may look like it but, no filler was used on this wheel below.
F) Using P400 grit, rub down the whole wheel including all the niggly bits like stud holes, any area touched with P320 grit, etc.....
I also used a dremel with the sanding attachment to do stud hole to remove loose paint and smooth it down.
Now, wipe over the whole wheel with panel wipe to remove any dust and oil and then use a tack cloth (sticky cloth) to remove any remaining dust, also make sure you get in the stud holes with tack cloth. I wore gloves from this point so the oils from my skin didnt get on wheel and risk contaminating the new paint causing bubbling, etc.....
Clean all dust off work surface and cover it all in newspaper.
Your now ready to start spraying!
2) PRIMER
As you can see, i used 3 different primers to make sure i get good coverage. First is etch primer, this "bites" in to bare metal to make it stick good. Second is some normal primer, and the 3rd is spray putty, its primer but hi-build and fills in any little marks left behind.
A) Use etch primer to cover any bits of bare metal, i just did the whole wheel to make sure. Only do good 1 coat of this making sure you get in stud holes, etc...
Was tempted to leave it like that, looks nice lol. As you can see, i have a halogen heater to help dry paint as its quite cold in workshop.
Cool Give the wheel 3 good coats of filler/high build primer! It doesnt matter too much if you get runs in the primer as you'll be flatting it back anyway!
I used 1 coat of primer and 2 coats of the spray putty.
Primer
It is acually grey primer, not white like it looks like in photos.
Spray Putty
C) When the primer has dried (best to leave for 24hrs), spray on a very light dust coat of cheap black spray paint and let it dry (known as a guide coat)
D) With P400 grit paper sand the whole wheel until all of the black has gone leaving you with smooth, flat primer!
3) PAINT
Well me and luke (pugmarshall) got one with spraying the wheels today.
A) Wipe down the whole wheel with panel wipe!
Cool Remember its always better to spray several light coats than 1-2 heavy coats which are likely to leave runs!
C) Start to spray around the rim, inside the spokes, inside stud holes first leaving the face until last!
Inside
As you can see, we cut out a cardboard piece so we didnt get overspray. Just doing them with matt black inside so the silver doesnt show up. Only did 1 coat and 1 coat of lacquer.
Lacquer
D) leave the first coat for a minute or so until it is sticky to touch. DO NOT TOUCH THE PAINT! Everytime you do a coat spray some inside the wheel (where the tyre goes) and touch that to find out when its sticky.
E) Same again rim, stud holes, inside spokes THEN face last
F) Keep doing this until your happy with the paint coverage as its hard to judge how many coats to put on as it depends on the paint, how thick you put it on etc but i recommend you do at least 3 coats!
Second Coat
Third Coat
Forth and Final Coat. As you can see there a colour difference as the paint i was using first was crap as they were leaving loads of tiny dots all over the wheels and it was like water. Even the lightest coat would leave runs. They must have been old cans of paint so i brought some new fresh cans to do top coat.
I rubbed down with P400 before applying final coat to remove runs and tiny dots.
Then i panel wiped it to remove dust and went over it with a tack cloth aswell to make sure. Now, final coat.
Looking good now. Now Lacquer time.
4) LACQUER
a) Do not panel wipe the wheels this time!!! and apply the lacquer about 30minutes after final coat of paint.
Cool The first laquor coat should be VERY light as is it helps the following coats to adheer! Remember to spray the rim, stud holes etc first and leave the face until last!
c) Leave until laquor is sticky to touch. Again, DO NOT TOUCH THE LACQUER! Everytime you do a coat spray some inside the wheel (where the tyre goes) and touch that to find out when its sticky.
d) Same again but put a slightly thicker coat on this time!
e) You should be putting 3-4 coats of lacquer on!
First Coat In Front Of Heater
Second Coat
Third Coat
The lacquer is still wet and you need to leave them for at least a week now to harden before doing anything else to them (e.g. polish, putting tyres on)
5) FINISHING
a) You will no doubt get bits of crap in your laquor, which, unfortunately is unavoidable so...
Cool Get some P2000 grit wet&dry and GENTLY rub away any specks in the finish remembering to keep the paper wet!! you can also smooth out small runs too but dont go crazy as you will rub through the laquor and it'll be time to start over again!
c) You will now be able to see dull patches where you have been sanding!
d) Get some G3 cutting compound (from any motor factors) and polish the whole wheel with it! Remember to keep the wheel very wet whilst using the G3! never use it dry!
e) The G3 is basically t-cut but 10times as coarse! so just like t-cut you need to polish the wheels with your normal car polish to protect the paintwork!
Keep Checking Back!
WANTED URGENTLY: DRIVERS WING, DRIVERS HOCKEY STICK!
Posted 28th Jan 2011 at 17:32
davewagon
Good guide this!
Roughly how many cans of everything did you get through doing the four wheels?
Dave
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 4th Feb 2011 at 03:53
ash 306
davewagon wrote:
Good guide this!
Dave
1 can etch primer 500ml
2 cans of spray putty (yellow stuff) 500ml each
1 can of grey primer 500ml
3 cans of paint 300ml each
4 cans of lacquer 300ml each
Posted 4th Feb 2011 at 17:25
silky
Rough cost per set of 4 wheels ?
Posted 4th Feb 2011 at 20:22
chrisd306
Cracking guide mate
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 4th Feb 2011 at 21:06
vernam616
Very good guide mate
Always seemed to go wrong whenever i tried
We have a place local to us which shotblasts them and powdercoats in any colour for £25 per wheel
Audi S3 Black Edition
Posted 4th Feb 2011 at 23:36
Good guide Cool
I'm with you though Wink
I've done alloys in the past,and now would rather take them to someone else than spend the hours/days doing it myself like you need too doing your ownBig grin
Posted 5th Feb 2011 at 01:58
tea boy
coskev wrote:
Good guide Cool
+2
Excellent guide.
Excellent result, too.
I have done all this a myself and my conclusion is that life is too short to spend it sanding wheels.
Also aerosol painting is terribly expensive.
When I can be ar5ed mine are going to the powder coatersWink
EDIT
Whitewash your workshop, makes them much brighter & more invitingWink
Make tea, not war.
If it ain't broke......fix it until it is.
Posted 5th Feb 2011 at 21:26
sixysix
Looks like a really good job there Thumbs up
Did this myself a while back and it is time consuming to do it all properly and glad I did it, just not sure if I would do another set any time soon as there is a lot of time put in to get them looking really good.
I still swear by Micromesh over sandpaper/wet & dry though, it's really good and easy to use and I got rid of all orange peel on my wheels after spraying with cans...
Around two years on and the wheels are still pretty much as new (I don't kiss curbs) LOL
Take a look
Posted 5th Feb 2011 at 22:45
simonjames
Yeah agree'd it is very time consuming to get a good job, i wish more people realised the time that goes in to a set
MY EBAY ITEMS
07943066306
Posted 5th Feb 2011 at 23:13
Good effort Thumbs up
When mine are due for a refurb i'll definitely not be doing them myself, took me bloody ages to do mine LOL
Posted 6th Feb 2011 at 02:38
m8pughdi
exellent guide hant got the patience i think .
no smoke it pretty economical
Posted 24th Apr 2011 at 21:51
ballardpaul
So what's better spraying something letting it dry then lacquering it or spraying something and then lacquering straight after like this guide suggests?
Nissan 350Z (300 BHP)
Posted 27th Apr 2011 at 02:00
orta
Admin can we move this to FAQs please?
CLUB BLACK RALLYE
||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar||
Posted 29th Nov 2014 at 16:19
