Author Subject: HDI Rattle
bennn
Unfortunatly im not posting about a 6 because i dont have one anymore Sad but hopefully someone will still be able / willing to help me.
My HDI has developed a bit of a rattle coming from the crank end of the engine. The rattle is only on idle upto about 1200RPM and its not all the time either.
I assumed it was the crank pulley, but im not sure now as most people seem to report that the rattle is worst around 2000-3000RPM (at which point mine doesnt seem to rattle at all)
Ill have a good look at the weekend so has anyone got an idea of what to look at?
Is there anyway of telling if it is the pulley...eg will there be play, or will it look corroded etc.
Thanks
Ben
Cherry Red 306 HDI
Posted 28th Jan 2011 at 18:53
matt evans
If its the pulley they tend to shed tiny metal filings as they clatter, usually easy to spot round the pulley area. Dont bother with patern parts, gen pug is the way forward.
Could be injector noise, if it rattles under load but the noise goes away after 3000 rpm, its prob injectors and theres nowt wrong with that - loads do it.
If the pulleys really fooked you might be able to see it wobbling as the engine is revved. If they get too bad, they can disintegrate and have been known to throw the aux belt through the cam belt cover causing untold misery and tiny tears of doom.
honestly3k wrote:
owain wrote:
Posted 28th Jan 2011 at 19:00
fozzy_255
does it sound like this:
Posted 28th Jan 2011 at 19:05
bennn
Yeah ive heard the horror storys which is why im inclined to try and fix it rather than leave it.
I dont think its the injector noise because i dont have the rattle over 1200RPM.
Ill have a goose tomorrow and hopefully will be able to see whats at fault.
Hoping its an easy fix Confused
Cherry Red 306 HDI
Posted 28th Jan 2011 at 19:07
bennn
nope, but it sounds exactly like this:
Clicky
Cherry Red 306 HDI
Posted 28th Jan 2011 at 19:10
russbez
not sure mate
sounds like a pulley or bearing about to shit the bed
My Rallye project thread
Posted 28th Jan 2011 at 20:31
bennn
Hmmm perhaps it is the crank pulley then, ill have a fiddle at the weekend.
Cherry Red 306 HDI
Posted 28th Jan 2011 at 21:20
do get it sorted asap, as the pulley can take the timing belt with it, most places stock the pulleys as they are a common failure.
Posted 28th Jan 2011 at 22:36
Get it sorted ASAP mine went and I ignored it till it spat itself around the cam cover and caused the cam belt to jump a tooth Sad you can get a later solid one rather than the shit 2 piece toss they usually run with Wink
Posted 28th Jan 2011 at 22:40
