Author Subject: Banging gear stick?
tickious
Hi, pick my 205GTi6 up at weekend, everything seemed fine besides the gear stick did a weird rattle from side to side thing. I'm not sure if it’s bumps in the road related, but it’s like the frequency keeps it going. At one stage it banged from left to right for about 5 seconds. I even stopped to check if I had a loose wheel. Any thoughts what this might be? Please!
205 GTi6
Posted 29th Jan 2011 at 05:03
smighall
Smeg-all
Under load / hard acceleration? Usually a driveshaft on the way out causes that.
Meh
Posted 29th Jan 2011 at 06:09
tickious
Bugger! thanks for that, any idea how much to sort? Also do you know if it will cause damage to anything else if it does go? Or am I ok to drive it til it brakes? Nice pic BTW. I had to sell my Tiger R6 on TB's to free up some till. Loving this little 205 though! It's got a roof and everything! Just got back from a little test hoon, and it certainly puts a smile on the face!
Big grin
205 GTi6
Posted 29th Jan 2011 at 22:18
jord294
are we talking the o/s driveshaft, because of wear in the support bearing, or most likely to be either driveshafts?
Posted 30th Jan 2011 at 00:09
smighall
Smeg-all
Can't remember tbh it's been a while since i had the car or issues. But I remember when i used to shag driveshafts on my 205GTI6 the gearstick would do that. Will probably put a bit more strain on engine mounts (depending which ones they are and how you drive it) but otherwise can't see it causing too much of a problem. Hell i did 15 odd laps at Cadwell after one of my driveshafts shat a brick.
Meh
Posted 30th Jan 2011 at 01:55
usually the inner CV if the gearstick does a dance, worn intermediate bearing tends to just cause a rumbling noise.
Posted 30th Jan 2011 at 01:58
rallyeash
melksham motorspares do service exchange driveshafts for around £50 from memory. had some 309 ones done a couple of years ago.
Thumbs up
i actually wanted to change my front end to 309 setup so ordered 309 gti shafts and gave back the old 205 onesLOL
309 3dr K20 Type R
Posted 30th Jan 2011 at 02:08
Top engine mount could be buggered ?
Worth a check Wink
Posted 30th Jan 2011 at 02:11
tickious
Cheers Guys! I'll look into all thatRoll eyes
Thumbs up
Sounds like a plan. Are the 309 ones stronger? And is it a straight swap or does it need extra fettling? Big grin
205 GTi6
Posted 30th Jan 2011 at 03:25
rallyeash
no, but there longer, you need them if fitting 309 wishbones. a good gain as the track is approx 20mm wider and a simple wishbone and drivesahft swap.Smile
309 3dr K20 Type R
Posted 30th Jan 2011 at 03:36
which it may well be running already.
Posted 30th Jan 2011 at 03:47
tickious
I'll have my man take a look, what what.
The tricky bit is not letting the wife find out No No
205 GTi6
Posted 30th Jan 2011 at 03:54
miles
Worth checking to see if the engine's been tilted (allot are), I know this eats shafts for a past-time on allot of 205's
www.pugracing.com
Posted 30th Jan 2011 at 05:01
