Author Subject: Sump plug size? Oil temp sensor related
flynn_
Hi, I want to setup an oil temperature gauge for my pug as the stock one isn't that accurate. I heard that the sump plug is either 14 x 1.50 or 14 x 1.25. The website that I ordered the gauge from had some adapters but only in 14x 1.50 so thats the one that I ordered. I called up pug and they said it was 14 x 1.25 so where can I get that sized adapter from? Thanks.
Posted 30th Jan 2011 at 03:00
rallyeash
pretty sure its 14 x1.25.
im actually looking for the exact same thing so i can wire up my SPA oil temp and water temp gauge. merlin motorsport only list m14 x 1.5
309 3dr K20 Type R
Posted 30th Jan 2011 at 03:08
flynn_
Just looked on Demon Tweaks and they've only got 14x1.50 or 12x1.25 as wellAngry My oil change is overdue so I want to sort it fastishShock
Posted 30th Jan 2011 at 03:12
rallyeash
been on there also, surely somone must make them?
at worst could buy the M14x1.50 and get a M14x1.25 dye to change the thread.
309 3dr K20 Type R
Posted 30th Jan 2011 at 03:16
I wouldn't put it in the sump plug, just remove the stock sender.
IMO there's no need though, they are accurate enough to give an indication that something is awry, you never need to be that precise with temps.
Posted 30th Jan 2011 at 03:22
rallyeash
ill be fitting one in the top sensor hole in thermostat housing for water temp and the front sump bung for the oil temp. mines on a 205 rallye so no temp gauges atall.
309 3dr K20 Type R
Posted 30th Jan 2011 at 03:34
ablister
when i used one, i used a durite oil temp gauge which had a 1/8" nptf sender so needed a 14x1.25 adaptor from demon-tweeks, change 'sender thread' to 1/8 npt and 'male thread' to m14x1.25
306 rallye, Richard Longman engine
rc10gt
Posted 30th Jan 2011 at 03:43
rallyeash
tidy, just what im after. will order two nowSmile
309 3dr K20 Type R
Posted 30th Jan 2011 at 03:48
flynn_
I could have sworn they didn't do an adapter for itCrazy I've just put the details of my sensor and required adapter and its come up with oneBlink My sensor is an M10 thread so different from yours but they still have an adapter it seems. Going to order one now, thanks for the link. Edit; is there any particular reason to go for short or long?Dry
Posted 31st Jan 2011 at 00:31
I bought the Demon Tweeks one and it does still go in, just takes a bit of grunt Smile
Don't bust your sump though.
Posted 31st Jan 2011 at 00:36
flynn_
Hi owain. Did you get the long one or the short one? And why was there a problem with getting it to go into the sump thread? It is 14 x 1.25, that is the right thread so it should fit in easily :s
Posted 31st Jan 2011 at 00:42
No idea why it was tight but it was, and it leaks unless you get it all the way in.
I got This one, M14 and 1/8NPT.
Posted 31st Jan 2011 at 00:44
rallyeash
i ordered the short one
309 3dr K20 Type R
Posted 31st Jan 2011 at 01:02
flynn_
I need the M10 one bud. The washer should stop any leaks you get, perhaps it was not seated correctly?
Is that the same length as the pug one?
Posted 31st Jan 2011 at 01:04
flynn_
Just found out the source of the confusion:
http://www.demon-tweeks.co.uk/Motorsport/Gauges_Instrumentation/Gauge_Pipes_Adaptors/LMA_Oil_Temperature_Sump_Plug_Adaptor/1773/1844
http://www.demon-tweeks.co.uk/Performance/Gauges_Dial_Kits/Fittings_Accessories/LMA_Gauge_Sender_Unit_Adaptors/812/1847
There two different sodding pages! No wonder I couldn't find the M14 x 1.25 sensor the first time round! Wonder what that is all about :S
Posted 31st Jan 2011 at 01:06
