Author Subject: Alternator /Charging WTF
Okay, I've been searching through for long enough now, and I've just run out of knowledge so hope someone can help.
My car mostly lives in the garage, and recently hasn't been being driven much. I had the dash all out to replace the heater matrix, came to start it up and battery was dead. Fair enough, I've had the car a year and I have no idea how long the battery's been in before that.
Replace battery, starts up fine. Run it for a bit, stop it. Start again, all's well. Start it up today (four days later) and it reluctantly starts. Bit weird, but still. However, go to start it again this afternoon and it's completely dead again.
Here's my conclusions so far:
1. The alternator is working. When jump started, there's 14v across the battery terminal *themselves* - not the cables going to them, but the actual terminals. Therefore the alternator must be working and giving 14v to the battery.
2. The voltage in the centre console is 12v with the engine off, and 14v with it on. Again, alternator must be working.
3. The could be something draining current. However I don't have an alarm, and I'm pretty sure the lights flash if the alarm is going off anyway? I also have barely anything else in the car any more.
4. After a 20-minute drive (having jump-started), I got back and turned off the engine. Immediately tried to restart it, and nothing - completely dead. Therefore anything draining current would have to be drawing hundreds of amps to immediately flatten the battery, and if that was happening then it'd pull it from the alternator when running and the car would idle really high.
The only conclusion I can come to is that I've maybe bought a dud battery that won't charge, but does that even happen anymore? That would imply however that it was coincidental that the old one died then the new one was dud? Seems unlikely.
If anyone can help, please do. I'm all out of ideas...
Posted 16th Feb 2011 at 23:37
battery warning light on the dash work ok?
Posted 16th Feb 2011 at 23:44
How do I know if it's working? What's it meant to do?
Posted 17th Feb 2011 at 00:17
the light should come on with ignition, and go off when you start the car.
when this bulb fails (or any part of the wiring to it) the alternator doesn't charge till the engine is revved up beyond roughly 3k rpm (IIRC) its the exciter wire, the smallest one connected to the Alt Smile
Posted 17th Feb 2011 at 00:36
Hmm, that sounds like exactly the thing that could've happened - in fact the left hand side of my dials weren't lit up and I had to give them a comedy whack to get them lit up.
In saying that, that was at the start of the drive.
I'll have a check tomorrow, cheers matey Smile
Posted 17th Feb 2011 at 00:40
james_gti6
earth out the warning light wire to check that the bulb is ok and check you have 12v on the battery feed. if you have them two, take the alternator off, if its a valeo unit, you will probably find the sliprings are worn down to the rotor shaft.
if i dont see you in the mattress il see you in the spring
Posted 17th Feb 2011 at 01:55
But surely if I have 14v to the battery then that's that, it should be charging?
Or have I misunderstood somewhere? Is it possible that the alternator can be knackered and still be giving 14v?
Posted 17th Feb 2011 at 02:32
james_gti6
sounds like the alternator is charging, put a amp meter between the negative battery and disconnect the battery cable from the alternator, if the rectifier as a blown it will still charge 14v, but there may be a drain when turned off. a diode works like a one way valve and if it has gone it will back feed through the dud diode causing a drain.
or could be a bad earth
Posted 17th Feb 2011 at 02:44
Well this is what I don't get, 14v is being delivered to the battery, and yet it just doesn't seem to be being charged.
Is there anything that could be wrong which would mean that the voltage is being delivered but nowhere near enough current?
Posted 17th Feb 2011 at 03:01
james_gti6
possibly a dud new battery. worth getting it checked to rule it out
Posted 17th Feb 2011 at 03:02
cwspellowe
Check the battery voltage, if it's a dud it will hold a voltage for a few seconds then drop off to nothing.
Bye bye Sundance Kid Sad
Posted 17th Feb 2011 at 06:59
Charge the battery independently, then do a load test on it and see what the outcome is.
When the battery is in the car, and the engine is running without any jump leads etc attached to it, can you read 14v (roughly) across the terminals??
Also, as Mei says, when you turn the ignition on, does the battery light illuminate, and then when the engine starts it goes off??
Stan.
Posted 17th Feb 2011 at 12:54
Chris - yesterday I had a meter on the voltage having turned the engine off (this was earlier in the day) and the voltage dropped from 12.8v down slowly, and I got bored and did something else at about 12.5v - however as it's a 12v battery I wouldn't be surprised to see it drop *to* 12v. I'll check it this evening having left it a day, see what the voltage is at.
I've also got one of those clamp-type ammeters at work, I'll nick that to see where current's going.
How to I know (short of jacking it all up) which wire goes to the alternator? Presumably just a large wire running to the positive terminal of the battery? I seem to remember there are two or three, I assume the largest positive cable will be going to the starter motor.
Stan - yes, the car running by itself has 14v across the terminals, this is what I don't understand. Don't know about the battery light yet, I'll check that tonight also.
I think I've got a trickle charger at my parents, I'll grab that. Once it's charged, what's the best way to load test it?
Cheers people, much appreciated.
Posted 17th Feb 2011 at 13:17
mark.evs
daft question mate, have u checked the connections on the starter? sounds like your battery charging system is ok, a loose terminal on a starter will cause it to start ok 1 min then slow or no start the next. i've had the problem b4.
My GTi6 track project
White Rallye project
Posted 17th Feb 2011 at 18:13
Fair point, but the car goes from not starting to starting perfectly with a booster attached.
Good thought though, cheers.
Posted 17th Feb 2011 at 18:50
mark.evs
either that or could be corroded terminals on the earth wires onto the gearbox or body. Had that problem too, the joys of owning a pug i suppose.lol
Posted 17th Feb 2011 at 19:04
True, but again I wouldn't get 14v across the battery terminals if that were the case.
I've invested in a decent battery tester which can apply up to 500A of load to the battery, so I can add that to my list of things to test. I'm thinking:
1. jump the car, take it for a 20-minute drive, then check the voltage. If it's 14v, it should've charged.
2. Remove battery terminals with the engine running to stop anything discharging the battery when the engine stops
3. Give the battery a load test. If it fails, it's a dead battery for sure. If not, at least I'll know to look elsewhere.
Posted 17th Feb 2011 at 19:28
mark.evs
if u had a week connection u would get the 14v through it but the pull under starting can still be affected. what are the sides of the battery like? are they bulged? bulging on the side is a common sign of warped plates in the battery, caused buy being cold or in a new battery, it could've been stored on a cold concreate floor in the wearhouse for a while.
Posted 17th Feb 2011 at 19:35
Good points mate, I'll add them to the list of things to check for Smile
Posted 17th Feb 2011 at 19:40
Oh my frickin God.
So, check the battery voltage - 12.5v. Interesting, hasn't dropped its voltage.
Go to start the car, just a click then nothing. Expected. Whip the battery out, get a load tester on it. Performs absolutely fine, exactly as you'd expect from a good battery.
Get the battery back in the car, ignition on. Battery light comes on. Okay, that's fine. Try the starter, and it fires up! What the hell...?
Turns out after all that - it was indeed a loose cable. But not in *any* of the places I'd looked, nothing was broken, nothing was frayed, it was just the thinner cable to the positive terminal was slightly loose where it bolts on.
It was still attached but only finger-tight. Tighten it up properly, and the car starts every time.
Turns out what must've been happening was that jump-starting the car wasn't actually what was making it start - it was the physical clamp from the lead then pushing the connection together properly. No matter it was so seemingly random!
So that's sorted, and thanks to everyone who helped.
Only slight annoyance is that I load tested the old battery and it was in fact completely fine. Can I find the receipt? Can I bo***cks.
Cheers again people, yet another lesson learned - just because a cable's in good condition and bolted to the battery, doesn't mean it's actually got a connection Doh
Posted 19th Feb 2011 at 17:27
