Author Subject: 306 gti faults list please help
liam.davies
I have just got a 306 gti which has had one owner from new (my mum) is a phase 3 w reg 2000 it has the following issues
alarm goes off when ever you lock car with fob
stereo does not work
rear centre brakelight does not work
bakelights on dash do not work
speedo stops working and car loses power (the worst problem)
any help or advice on these issues would be great thanks Liam
Posted 18th Feb 2011 at 01:08
mcfc1987
that's what i like to see, if a woman has to leave the house she takes the kitchen with her.
might have to get a bake light for the mrs.
get home b*tch! my pie is about to burn!
Posted 18th Feb 2011 at 01:52
mwl001
Welcome to the site,
These are fairly common problems, try searching the forums for these problems.
To get you started though:
Alarm: could be Ultrasonics, you can set the alarm without the ultrasonics : Press and hold the little alarm button on the steering column until the LED goes solid (not blinking) red before getting out of the car. See here for more details on alarms.
Stereo - if it doesn't work at all, check the fuse and the connector behind it.
No idea what bakelights on dash are, even if you meant brakelights, I'm still not sure what these are on the dash.
Speedo not working happened to me once and after a few miles trying to work out the speed based on gear and revs (using milepost markers on the motorway) it fixed itself and hasn't broken since.
Posted 18th Feb 2011 at 02:15
lotek
VVS sensor on top of diff casing ( white with silver foil protective casing)
Posted 18th Feb 2011 at 03:04
liam.davies
sorry cant type back lights on the dash clock dials speedo doesn't light up thanks for advice
Posted 18th Feb 2011 at 03:16
mwl001
Think back lights on dash and stereo are on same fuse so I'd check that, can't rememeber which fuse it is though.
Posted 18th Feb 2011 at 03:29
liam.davies
Thanks checked that didn't go at same time issues are coming thick and fast now Sad
Posted 18th Feb 2011 at 03:33
dan_s16
On the right side of the dash is a dimmer for the dash lighting, pop that out and there should be wiring plugged into the back of it but sometimes it can work loose and stop the lights from working.
Posted 18th Feb 2011 at 16:53
