Author Subject: Engine Problem
cescnathan
Can anyone give me an idea why my 6's engine still keep shaking and popping in exhaust system no matter i did below.
1) ICV, Map & O2 sensors have been replaced
2) All Engine mounts have been replaced
3) Inlet manifold & Exhaust inspected no leak
4) Spark plugs have been replaced
6) Timing Belt kits have been replaced
7) Injectors have been inspected and cleaned
Thanks!
Posted 4th Mar 2011 at 14:28
oecken
Air leak from somewhere? i know mine had a very small airleak and caused similar symptoms, and got worse as the hole increased. iirc it was one of the rubber pipes that had perished. but it took me a lot of money for the garage to figure it out, once replaced the car had never run so good, so it must have been there since i bought it.
Posted 1st Mar 2011 at 22:02
cescnathan
Thanks mate!
I'll check the rubber pipes tomorrow.
Hope it's the same problem as yours.
Posted 2nd Mar 2011 at 05:21
Dodgy coil pack??
Posted 2nd Mar 2011 at 05:58
Scrompy
Aka Quagmire83
stan_306gti6 wrote:
Dodgy coil pack??
+1
X-Box Live gamertag: Scrompy
PS3 tag: Scrompy
Posted 2nd Mar 2011 at 13:56
swiftyboi006
Does it feel down on power?
Black p3 Love
Posted 3rd Mar 2011 at 01:24
cescnathan
Yes, power down a bit absolutely.
Checked there is no rubber pipe air leak.
This situation appear on idle.
How to check the coil pack is dogdy or not? Check voltage?
Thanks mate!
Posted 3rd Mar 2011 at 06:36
Pull the plugs off the coil packs one by one and see if it makes a difference to the engine running. If the first one does, then put the plug back it's obviously working....when you get to one where you take the plug off and find the engine running is no different, you have found the dodgy one.....
Stan.
Posted 3rd Mar 2011 at 15:38
adonmall
Hi, I'd say that was a failed coil pack too. They cost £50 each new but you may be able to get a set cheaper from a member on the Club.
Posted 3rd Mar 2011 at 15:50
cescnathan
So I will check the coil pack this sunday.
Thanks you guys.
Posted 4th Mar 2011 at 05:13
cescnathan
After changed the coil packs, no engine shake anymore and i can enjoy my 6 again.
Thanks you guys!
Posted 14th Apr 2011 at 13:44
Glad to be of help mate, enjoy it! Smile
Posted 18th Apr 2011 at 03:52
