Author Subject: gti6/309mi16
johnj6939
hi am tryin to find out some info about a engine swop,, i have a gti6 that was a great car till i got hit from behind an been an no way repairable, my m8 has a 309gti that was runnin a mi16 on r1 bike carbs till he blow the engine up
hes wantin to know would the gti6 lump and gearbox fit an if not what needs to be done,, plus would it run on the wierin loom he was using for the mi16 with the r1 bike carbs as he wants to put the carbs onto the gti6 engine aswell
Posted 4th Mar 2011 at 07:36
rallyeash
yes its a straight swap, run the gearbox from the mi16 engine and clutch on the gti6 engine.
if im honest i would say the standard injection system would be better than the r1 bike carb setup unless its on proper mapped ignition which i doubt it is.
you can get a plug and play loom to run the standard injection system, spiky on here makes and sells these.
if you have your heart set on running the carbs, if you can afford to get proper mapped ignition do it, if its not it is possible to get an adaptor to run a dizzy off the exhaust cam which goes in place of the vacuum pump.
309 3dr K20 Type R
Posted 4th Mar 2011 at 13:34
miles
Also having done a couple of tests with OE injection and carb's on both Mi and GTi6 engines, they seem to loose power
But other than that a Re-angled Exhaust manifold and Custom D/P is all you really need
www.pugracing.com
Posted 6th Mar 2011 at 17:51
