Author Subject: Geometry print out
lewisdmz
All in all not too bad I reckon.
Rear toe isn't great but other than that fairly even.
...waits for the clever people to come and shatter my bubble built from ignorance...
Posted 9th Mar 2011 at 02:12
davedgti6
rear axle wants adjusting but everything else ok really, I did my toe by using string lines and by measurement my rear was spot on, although it was set by skip browns so it should be really,
Posted 9th Mar 2011 at 02:22
not bad at all, wont get many that close all round!
has it had beam mounts at all?
Posted 9th Mar 2011 at 02:23
lewisdmz
Not to my knowledge/service history. On 73k at the moment and I think it has had a gentle life.
Posted 9th Mar 2011 at 02:25
lewisdmz
I was surprised the rear has that much camber as standard, i thought over a degree of -ve camber is for wace cars only.
and Hondars with spoons super mega race arms.
Posted 9th Mar 2011 at 02:29
Xsara and ZX have more Big grin
Posted 9th Mar 2011 at 03:21
lewisdmz
zx's look awesome. Never see any of them about at all.
How come you asked if it's had rear mounts, is it easy to misalign the beam when you swap them over?
Posted 9th Mar 2011 at 03:43
not specifically that,. but wear in the front ones could cause the beam to sit off a little.
Posted 9th Mar 2011 at 03:45
The rear toe is just cos the beam isn't quite straight on the chassis. Bit of a front camber difference but nothing really to write home about. Guess you checked the tyre pressures before doing it?
Should get mine done tomorrow - should run about -1.5 camber on the rear iirc. Thats what my impreza ran too.
Breadvans look like they have a lot of camber as standard on the rear though?
Posted 9th Mar 2011 at 03:47
vts_tibi
is there a guide somehwere about how to align the rear suspension? (rear toe)
I would like to fit new rear beam front mounts and I want the settings to be spot on!
Are aftermarket beam mounts OK? Like Lemförder.
VTS
best 60' : 2.272
Team Trackday™
Posted 22nd Mar 2011 at 11:57
lewisdmz
Slight bump to this. I think you might have been right Welsh one, I have recently developed an occasional knock which sounds like it's coming from the rear whilst setting off.
Had the car on the ramp today and there is a tiny bit of sideways flex in the fronts and the rears do flex away from the car with not too much effort on a pry bar. Not as bad as I thought they would be but then i guess the weight of a car moving around is going to be a hell of a lot more than under 100kgs with a bar...
Posted 10th May 2011 at 00:00
