Author Subject: tapping from head
chezney55
right i am new to this site and was wondering if anyone could help! my gti 6 has started making a tapping noise from the head and i have been told that there is no oil getting to the head. what could the cause of this???
Posted 9th Mar 2011 at 23:34
pugjim
Do a search and you will find lots of information on tapping heads. Usually the aftermath of a poor repair after a timing belt failure.
Posted 10th Mar 2011 at 00:22
lotek
Yes cambelts snapped and they have done a poor job repairing it.
Posted 10th Mar 2011 at 00:57
Rich E Forum Admin
If it was quiet previously and it's just started tapping then oil starvation to the head is certainly a possibility. There is a one way valve on the oil feed to the head which can block up and cause this.
Check the timing first though to make sure the belt hasn't jumped a tooth, and loose spark plugs can give a tapping noise too.
Posted 10th Mar 2011 at 01:43
chezney55
Cheers for the replys going have have a look tonight so will keep you updated thanks again
Posted 10th Mar 2011 at 21:35
chezney55
Well good news give it a oil change with some oil flush in then put new oil in silghty thinner mix and its cured it will do another oil change after running for a bit cheers for the help! Dean Smile
Posted 12th Mar 2011 at 01:59
