Author Subject: Head Gasket What Parts do i need
davsin
Hi All,
Some Advise, What parts do I need to replace when I do the head gasket, ie timing belt, water pump, Gasket etc.
Or is there anyone who offers a exchange service?
renault 5 campus sold
sierra sapphire cosworth sold
Peugeot 1.6 xs sold and gone to car heaven
Audi S2 220hp sold
Audi S2 Modified 295hp sold
Audi A3 Quattro Sport 180hp Sold
Peugeot Dturbo Sold
Volkswagon Passat 4motion V6 Modified 230hp SOLD Peugoet 306 GTI 6 FOR SALE
Vauxhall Signum 1.9CDTI 189bhp (chipped)
Posted 11th Mar 2011 at 00:12
pugjim
davsin wrote:
Hi All,
Timing belt, tensioners, head gasket, inlet and exhaust manifold gaskets, valve stem seals, thermostat, thermostat housing gasket, water pump and gasket, aux belt, cam seals, rtv sealant, engine oil + filter, sump plug washer, coolant, head skim. Thats just about everything i would use when i do a head gasket.
Posted 11th Mar 2011 at 00:59
ryangti6
All the parts you have mentioned really, full gasket kit, headbolts, timing belt kit and water pump unless they are quite new.
Flush and renew the coolant and do an oil and filter change should see you good to go again.
Ryan
Posted 11th Mar 2011 at 01:02
no need for a full gasket kit tbh, there's lots in it you wont need, cheaper to just buy the hg + exhaust gasket cam seals and stem seals on their own.
might as well get machined pistons and a set of bottom end shells and piston rings whilst you're at it mind Ninja
Posted 11th Mar 2011 at 01:07
rallyeash
and make sure the lower pulley hasn't slipped..
309 3dr K20 Type R
Posted 11th Mar 2011 at 01:08
pugjim
I knew there would be a few things i missed off my list LOL
Posted 11th Mar 2011 at 01:10
davsin
Any advise on where to get parts or is GFS as good.
Audi S2 220hp sold
Peugeot Dturbo Sold
Posted 11th Mar 2011 at 13:20
pugjim
GSF should be fine for the head gasket and oil/filter, coolant etc, i would get the valve stem seals/cam seals and other little bits from the pug dealers
Posted 11th Mar 2011 at 14:02
davsin
Got a compression test and its not the head, took it for a blast and cleared out all of the dampness in the engine.
No smoke and running fine, just the timing belt now Sad
Audi S2 220hp sold
Peugeot Dturbo Sold
Posted 15th Mar 2011 at 07:09
