Author Subject: team pro 1.2 wheels
brett cullen
hi iam new to the forum i have a 1997 gti6 i race and i have done a search but want to make 100% before i order my new wheels because they will have to come all the way to australia , what et do i need to fit over brembos off a 406 coupe , for 16 x 7 team pro 1.2 wheel any info would help thanks
Posted 14th Apr 2011 at 16:18
velar
I run et15, this seems to be the norm.
Posted 14th Apr 2011 at 17:15
russbez
et15 sounds right iirc
welcome to club Smile
My Rallye project thread
Posted 20th Apr 2011 at 15:56
cosmic spanner
Moral objector
One thing to note, though - if you buy/source them direct from Rimstock you can get them with the centre bores direct-drilled for a 306, as opposed to many of the sets I've seen on here which seem to use plastic spigot rings. (These can melt on trackdays).
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 20th Apr 2011 at 16:18
brett cullen
thanks for the info , when i get the wheels i will post some pics of them on the car
Posted 20th Apr 2011 at 17:13
velar
has anyone actually melted their spigot rings, or is this an urban myth. ( I think most are made from a hard plastic that will acually burn ( or at least boil)before they melt. I would suspect all the grease will have been burnt from my hub bearings and ball joints before the spigot rings give up
Posted 20th Apr 2011 at 21:23
cosmic spanner
Moral objector
Yep. Last time at Oulton Park, one of the other guys there - Jeffers maybe? - was effing and blinding at his Pro Race 1.2s as the spigots had begun to melt (OK I didn't do a materials analysis myself, but that's what he said had happened) and he couldn't get the wheels off. Mine and Ash's were fine (same wheels, but direct drilled). Just something to keep in mind.
Posted 20th Apr 2011 at 21:38
velar
hmmm so it's not an urban myth Angry better keep a close eye on mine then!! thanks
Posted 21st Apr 2011 at 00:05
ravemercer
ET15
Apparently Rimstock charge about £5 per wheel for correct bore they stock bare cases with a 53.1mm bore re bore pcd/stud bore and paint then sell Two week wait mind but worth it I finks Cant wait to get mine 1 week to go.
Toyo R1 R Ninja
Posted 21st Apr 2011 at 02:40
velar
Or you could use alloy spigot rings on 73.1 bore wheels (these bad boys won't melt.)
Posted 14th May 2011 at 01:48
