Author Subject: 406 btcc cams
paddygti-6 Banned!
hi i have just built my gti-6 engine up with je forged pistons and steel rods it was bored to 86.5ml. i want to run 406 btcc cams or the biggest cam i can without solid lifters?? any ideas guys??
pat
Posted 24th Apr 2011 at 14:58
rallyeash
look at the specs on the cat cams website. should say what you can and can't run. im running 109's in my engine. although i think you can run 110's on standard lifters
309 3dr K20 Type R
Posted 24th Apr 2011 at 16:40
miles
Why use BTCC cams, there made to a regulation so you can get allot better for cheaper, and they would all use Solid lifters anyway.
www.pugracing.com
Posted 24th Apr 2011 at 18:58
paddygti-6 Banned!
btcc have very long duration and can make 240bhp
pat
Posted 24th Apr 2011 at 20:05
rallyeash
not always best though, you will struggle to make 240 with a standard head.
you can make 270+ on that bottom end with the right head, cams, solids etc
309 3dr K20 Type R
Posted 24th Apr 2011 at 21:31
paddygti-6 Banned!
i dont want to go solid lifters tho i aim to get around 220 bhp is that to much to ask of hydro lifters?
pat
Posted 24th Apr 2011 at 21:36
rallyeash
im running 87mm pistons, 88mm steel crank, forge pistons, steel rods, cat cams 109 retaining standard head just with a small amount of work, 4 branch maniflow manifold, jenvey throttle bodies, 8 injectors, satchell inlet manifold, dta ecu and its approx 230 bhp
309 3dr K20 Type R
Posted 24th Apr 2011 at 21:45
paddygti-6 Banned!
iam getting manifold anyway. so i could run 110 cams and achive around that bhp retaining the gti-6 inlet that is a btcc one??
pat
Posted 24th Apr 2011 at 21:48
rallyeash
just checked there website, requires "custom parts" where as the 109s are oem parts
don't get hung up on the "btcc" stuff, generally its overpriced when much better can be bought for cheaper. the "btcc" engine had to run inside regulations so were built to a tight spec, why would you want to build your engine to that?
the inlets aren't all that either, again were devolped for regulations as a single t'b had to be retained.
either way you will need an aftermarket loom, ecu and a proper mapping session
309 3dr K20 Type R
Posted 24th Apr 2011 at 21:56
paddygti-6 Banned!
well iam trying to build on a budget as do not have funds for itbs my head has piper valve springs in with retainers also i got them so i can get the bigest cam in before going solids??
pat
Posted 24th Apr 2011 at 21:59
matty_rallye
I would suggest that the 109 catcams may be best for what you are looking for.
2.1 16v 306 Rallye.
Posted 25th Apr 2011 at 00:50
miles
Also different cams need different springs to suit so another point to watch,
No idea on Piper spec as I avoid them at all costs, the companies had more names than I care to remember which must say something
Building on a Budget can be more expensive in the long term,
www.pugracing.com
Posted 25th Apr 2011 at 01:10
henrik c
What did you pay for those JE pistons? And what are the 1:10 or...
/Henrik C
Posted 19th Sep 2012 at 09:51
fatlapit
86.5 is standard bore!!
Posted 19th Sep 2012 at 10:23
You'll notice the chap is banned so won't reply.
  • Posted 19th Sep 2012 at 10:33
    GTI-6
    how'd he manage that one?
    Love thy 6
    Posted 19th Sep 2012 at 11:02
    No its not.
    Posted 19th Sep 2012 at 12:15
    fatlapit
    Wel my 87 were one size overbore so
    Posted 19th Sep 2012 at 12:29
    ryangti6
    Standard bore is 86mm
    Ryan
    Posted 19th Sep 2012 at 12:41
    Rich E Forum Admin
    One size for that manufacturer, but some do 86.5mm as an overbore size.
    Think about it... 86x86 = 1998cc, 86.5x86 = 2022cc
    Posted 19th Sep 2012 at 12:48
    Yup, Tis a perfectly square engine.
    Posted 19th Sep 2012 at 14:31
