Author Subject: slimline fans
306er
Has anyone got a pic of how they have installed a
universal slimline cooling fan?
i want to set one up from a switch in the car?
cheers
diablo 6 black 6 China Blue GTI 6
Posted 28th Apr 2011 at 01:41
smegal
All supercharged people have them but they'll be plumbed in to the std wiring.
Just fit it and add a relay and switch.
Or you could fit an aftermarket thermostatically controlled unit (assuming you are doing this because yours don't work)
Ex SC-6
Now in a Megane R26
Posted 28th Apr 2011 at 01:50
chrisd306
Mine are held on by counter sunk bolts that wont rust and nuts, forced through the cooling fins, been all good for about a year and a half no problems yet.
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 28th Apr 2011 at 02:10
rallyeash
can buy proper mounting kits to hold it onto the rad or just loop a cable tie through it in each corner, what i've doneSmile
309 3dr K20 Type R
Posted 28th Apr 2011 at 02:45
chrisd306
thats how the slimline fan is fitted on the 8v turbo gti6 ive got, just with cable ties works a treat
& Audi Q5 S Line
Posted 28th Apr 2011 at 03:00
Any idea how thin rad tubes are? No way I would force a dissimilar metal through a radiator. Elecrtrolysis will eat the tubes away around the bolts, add some salt and rain come wintertime and you will have a failed rad super fast. If you must mount them though like that use heavy duty plastic tie wraps, but it wants to be secure because any chafing will hole the rad quickly too. Best to fabricate some propper support brackets and do the job right. Takes a while longer but the rad will last a lot longer as a result. Tust my two pence worth...Wink
Posted 28th Apr 2011 at 17:08
rallyestyle
The proper nylon mounting kits for the fans are spot on, no need for anything fancy really No
Just Drive It
Posted 28th Apr 2011 at 19:30
chris with a pug
yeah I am going to buy the kit with the fans, its how all the kit cars do it, unless you want another job to do James
Posted 28th Apr 2011 at 20:43
No thankyou Christopher, plus you have your own welder and the neccessary skilz already Wink
Posted 28th Apr 2011 at 20:52
chris with a pug
can you PM or text me ur number as I lost my phone
Posted 28th Apr 2011 at 23:34
306er
Thanks for that, bare with me but how have you put bolts throw the rad without damaging it.
Posted 28th Apr 2011 at 23:51
Short answer is, you can't. Invest in the rubber mounting kit that does'nt damage the rad. Levering the fins out of the way with a screwdriver and pushing metal bolts through is a bodge way of mounting a fan and can very easily cost you a radiator.
Posted 29th Apr 2011 at 01:28
rich_w
+1.
Don't use bolts, the thread acts like a file Yes
Contact Details:
07732 822546
Posted 29th Apr 2011 at 01:33
I saw an ideal setup on a 205, but same principle, tubular and angle frame work and bolted the fans down rather than fixed to the rad, Will see if I can dig a picture out, made by colin satchell for a customer iirc.
Posted 29th Apr 2011 at 01:54
rallyeash
Spec R also do proper framework for mounting double fans on radiators, seen it on a few cossie's up there and looks spot on
309 3dr K20 Type R
Posted 29th Apr 2011 at 18:47
