Author Subject: 306 HDi Question
cornish_pug
I've got a fuel leak on my 306 HDi Cry and it's coming from what looks like a small black box near the high pressure pump. It looks like the fuel line from the tank goes into it and the line coming out from it goes to the fuel filter housing.
The leak itself is coming from the green connector on this black box. Does anyone know what this black box is called??
Here are some pictures.
Thanks
cornish_pug has attached the following image:
Team Diesel
Posted 29th Apr 2011 at 23:52
fozzy_255
I don't recall seeing this on my HDi, got any other pictures of it
Posted 29th Apr 2011 at 23:53
cornish_pug
Here you go
Team Diesel
Posted 29th Apr 2011 at 23:55
fozzy_255
Yeah im almost certain i don't have that, mines one of the first HDi's built so likely to have been put onto the later models
Posted 30th Apr 2011 at 00:02
tvrfan007
It's a reheater. The plug can only be for a temperature sensor if it's fuel side, so suggest having a look at the thread. I have it on my X reg, lemme fish out the diagram.
Edit: Here you are
I had to replace the diesel link to it many years ago when a truck tyre shard punctured it. Was a messy job as you get diesel everywhere. Your description tells me it's the plug that's leaking not the fuel lines?
Fuel goes tank LP Pump->heater->filter->HP pump-> Leakoff/used->cooler->tank
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 30th Apr 2011 at 00:09
cornish_pug
The fuel is coming out of the slot for that green connector, so could the housing be cracked causing it to leak out of the socket??
Team Diesel
Posted 30th Apr 2011 at 00:07
fozzy_255
What exactly does it do, heat fuel? Whats the benefits of this
Posted 30th Apr 2011 at 00:08
cornish_pug
Saves the need to use glow plugs i guess
Team Diesel
Posted 30th Apr 2011 at 00:10
tvrfan007
To change the viscosity of the diesel prior to the HP pump. Smile The fact your pump is pressurising the rail at 1400 bar is why you don't need glow plugs!
Maybe the plug is a temp sensor that's come loose. I can't comment as i'm 7000 miles away from my HDi. Razz I'm just looking in servicebox now.
I'm Si btw Tee hee
Posted 30th Apr 2011 at 00:11
cornish_pug
Any idea on prices of these??
Team Diesel
Posted 30th Apr 2011 at 00:13
tvrfan007
00001579Y6 FUEL REHEATER 20.49 GBP 24.59 GBP 24.59 GBP
Seriously fella, it can only be a temperature sensoror a direct element if it's got access to the diesel. I can't imagine what else would be in there, and sorry but I can't look at my car lol.
I'm Si btw Tee hee
Posted 30th Apr 2011 at 00:21
cornish_pug
I cleaned the connector slot & disconnected the fuel in pipe. When I reconnected them & let the engine run, fuel dripped from the green plug. I thought it may have come from the pipe directly above it but that was dry. So I un-plugged the green plug once again and found diesel inside the slot for it.
Team Diesel
Posted 30th Apr 2011 at 03:12
tvrfan007
Random. My only concern in that case is what actually is letting the diesel through. Was there any obvious damage to the thread? Wrapped it with PTFE tape and re-threaded?my local Peugeot parts man is pretty good, that's the kind of thing i'd go and ask him about.
I'm Si btw Tee hee
Posted 30th Apr 2011 at 11:41
cornish_pug
There is no thread on this connector, it's a push & click type.
Team Diesel
Posted 30th Apr 2011 at 13:05
tvrfan007
Are you saying that whatever it clips onto has no thread? In which case, you need a new reheater. Simples.
Got a good up close pic yo?
I'm Si btw Tee hee
Posted 1st May 2011 at 01:05
cornish_pug
I have a new one ordered Smile
Team Diesel
Posted 1st May 2011 at 14:17
tvrfan007
I meant of the leak. Laugh
Hope it solves the probs. Smile
I'm Si btw Tee hee
Posted 1st May 2011 at 14:38
cornish_pug
New part is now fitted and all is well Smile
Thanks tvrfan007 Cheers
Team Diesel
Posted 8th May 2011 at 00:22
tvrfan007
Thumbs up
I'm Si btw Tee hee
Posted 8th May 2011 at 01:09
