Author Subject: indicator clicking sound when indicators not in use
hayden
Ive only ever had 306's in my 5/6 years of driving, first was a 1.4 and I now have a gti 6.
Both cars have had an issue where I can be driving along and suddely I get the clicking noise that would be made if my indicators were on.
This can go on for the entire journey, some times is just one click then stops for a while.
Is this a known issue with these cars? Any tips on what the issue could be?
Cheers,
Hayden.
£150 a month insurance, errrmmm no chance of putting any mods on yet! ahaha
Posted 8th May 2011 at 18:26
dan_s16
Yes it's very common. What happens is over time the contacts in the switch get worn down and the metal that is worn off ends up in the grease. It eventually has so much metal in it that it then becomes conductive and starts causing problems with the relay.
You can either remove the switch and disassemble it which isn't too hard. Use an electrical contact cleaner to remove all of the grease and you may find the the contacts need turning 90 degrees if they have worn too much. Then apply some new grease suitable for electrical gear or get a replacement switch from someone breaking a gti 6 on here but a second hand one may have the same problem. The other option is to buy a new one but you need to make sure you get one for dual beam headlights that the higher spec 306s have otherwise your high beam headlights won't work properly.
Posted 8th May 2011 at 20:14
hayden
Thanks Dan, very helpfull!
Posted 8th May 2011 at 20:18
