Author Subject: WONT IDLE
simbob
Hi guys hope fully one you can help, My rallye wont idle, I've changed the coil packs, and idle speed control valve, and changed the spark plugs for new genuine items. HELP HELP please cheers sim
Happy to be back in a 306 again!
Posted 11th May 2011 at 00:19
mwl001
Have you done an engine management system reset (i.e. disconnect battery, leave it for a bit, reconnect it and go for a drive?)
Posted 11th May 2011 at 00:41
simbob
Cheers I'll try it
Posted 11th May 2011 at 00:50
Check the wiring to the ICV too.
Does it run ok otherwise?
Posted 11th May 2011 at 01:46
simbob
No it doesnt idle what so ever !!!!!!!!!!!!!!!!
Posted 11th May 2011 at 10:08
simbob
just tryed the reset and taken her for a run no change :-( PLEASE HELP
Posted 11th May 2011 at 21:47
bennn
Tried disconnecting the ICV and seeing if it idles then?
Cherry Red 306 HDI
Posted 11th May 2011 at 21:49
lotek
if you have replaced the ICV then
switch the ingition on as far as it goes but not enough to start , wait, and repeat like 5 times
This will help set the position of the piston.
after that try and start car. Yes
Posted 11th May 2011 at 21:56
simbob
Hi just tryed to do as lotek has suggested still no joy :-(
Posted 11th May 2011 at 22:24
puglover Banned!
is it all over the place going up and down or just idle speed is high??
Posted 11th May 2011 at 23:14
mattgti6phase2
is the TPS plugged in?
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 11th May 2011 at 23:25
simbob
It not all over the place just won't idle :-( everything is plugged in as it should be . Just tryed starting it without the icv unplugged and is the same :-(
Posted 11th May 2011 at 23:52
bonzo
map sensor maybe?
Ninja Black Rallye Ninja
Posted 12th May 2011 at 00:03
simbob
How do I check if it is or not ????
Posted 12th May 2011 at 01:09
bonzo
I just replaced mine, guess you could try and give it a clean with some carb cleaner, but I don't know if that will be effective or not.
Posted 12th May 2011 at 07:18
mattgti6phase2
I bet it's something small and simple that you have just missed.
Follow the process of what you did from start to finish and you may stumble across the problem. Did you secur the icv properly? Eg are the the 2 bolts tight enough? They're may be an air leak if it won't idle Dunno
5 x a 306 owner!
Posted 12th May 2011 at 12:25
simbob
Hi all car is fixed it was the map sensor. thanks for all your help
Posted 16th May 2011 at 16:54
bonzo
Thumbs up
Posted 16th May 2011 at 17:33
