Author Subject: ABS not working
tarret
hi can anyone help,
my abs was working fine until the snow we had last year =/ everytime i was braking it would judder and one of the relays on the abs unit under the bonnet was making weird noises, then just packed up completly,
so i thought it was the abs little black box so i replaced that and still doesnt work,
does anyone know what it could be?
the ABS pump maybe?
Posted 11th May 2011 at 02:57
fordygti
Have you had a look to see if ur abs sensor isn't damaged atall?
Big grin
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 15th May 2011 at 19:28
mik
The first things to check if the ABS starts playing up is gapping and function of the sensors, and whether the toothed sensor rings are reasonably clean and free from corrosion. Could just be winter crud somewhere. You say "one of the ABS relays" which suggests the problem is just one wheel, pointing to a sensor or toothed ring problem. First thing to work out is which wheel. I had an ABS malfunction on another car once when the garage was replacing wheel bearings as the sensor was malfunctioning after they dented a couple of the teeth with a hammer!
Cherry Rallye SOLD
Posted 16th May 2011 at 00:14
oldbrownshoe
I had the same problem and solved it after cleaning all sensors.
another option i can think of is water contaminating
the brake fluid in the ABS chamber (20cc volume)
this fluid won't Drain in the standard Drainage process and need special BOSCH system to drain it.
French military victories?
Did you mean French military defeats?
Posted 16th May 2011 at 20:23
tarret
ill check the sensors rings make sure there all good,
where are the abs sensors located?
cheers guys Thumbs up
Posted 17th May 2011 at 02:27
mr swampy s16
**BAD SELLER**
I have a set of the relays here, they the round pin ones?
Posted 17th May 2011 at 02:36
tarret
the relays that packed up are in the little black abs ecu box, which cant seem to replace, ill have alook at the sensors if not ill let you know Smile
Posted 18th May 2011 at 01:52
mr swampy s16
**BAD SELLER**
They are in there tight but they do come out
Posted 18th May 2011 at 01:55
