Team Diesel
| Author | Subject: Torsion Bar, Spline Rotation |
cornish_pug
Regular Location: Marazion Registered: 18 Dec 2009 Posts: 368 Status: Offline |
On my 306 the drivers side Torsion bar is 15mm lower than the passenger side since i've had the car, 6 months now & it hasn't got any lower on this side in that time, people have said to me it's a knackered beam, but i've come to the conclusion thats it's just miss alignment of the drivers side torsion bar. So basicly i need to turn the bar back 1 spline (15mm approx). Which direction do you turn the drivers side to rise the ride height for this side.________________________________________ Team Diesel |
you just set the height of the trailing arm and slide the torsion bar in wherever it goes, there isn't a specific mm per spline recorded.there must be something wrong there to cause it to sit lower. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cornish_pug
Ok, i've just read about the splines, according to Haynes the splines on the passenger side disengage just before the drivers side, thus allowing you to make adjustments on either end. Before sliding the bar back in place.________________________________________ Team Diesel |
Rich E
I think you've got confused somewhere. You can't adjust the height on the drivers side without removing the torsion bar on the drivers side.When you say the torsion bar is 15mm lower do you actually mean the ride height is 15mm lower? ________________________________________ Rich |
cornish_pug
Rich E wrote: I think you've got confused somewhere. You can't adjust the height on the drivers side without removing the torsion bar on the drivers side. When you say the torsion bar is 15mm lower do you actually mean the ride height is 15mm lower? Yes drivers side sits 15mm lower when the car is on the ground than the n/s. It always has done since i've owned the car ________________________________________ Team Diesel |
Bent stub axle ? |
as above, or the gound where you park is not flat ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
martinj
Regular Location: Berkshire Registered: 12 Feb 2007 Posts: 322 Status: Offline |
or mis-aligned end plates on the ARB maybe?________________________________________ - Maxi rear axle hub spacers +53mm per side- Maxi front steering rack extensions +40mm per side |
Do you keep a fat bloke in a back seat at all?________________________________________ Membership expiring soon, get in contact on our new little forum project. |
bennn
Seasoned Pro Location: Shrewsbury Registered: 05 Sep 2008 Posts: 2,705 Status: Offline |
When i adjusted mine on my first 6 there was about 7mm difference between sides. I think its normal and if you couple it with uneven ground i doubt 15mm is anything to worry about.Even if it is lowering the other side to match isnt the right solution! ________________________________________ Cherry Red 306 HDIChampionship White Integra DC5 Type R |
Rich E
simongti6 wrote: Rich E wrote: I think you've got confused somewhere. You can't adjust the height on the drivers side without removing the torsion bar on the drivers side. When you say the torsion bar is 15mm lower do you actually mean the ride height is 15mm lower? Yes drivers side sits 15mm lower when the car is on the ground than the n/s. It always has done since i've owned the car As noted, many cars left the factory with a small difference in ride heights but 15mm is excessive and unlikely to be due to assembly tolerances. I've just looked back at your older posts and given that you've posted in an older thread that you have arch rubbing on both sides I would say the trailing arm bearings have collapsed. ________________________________________ Rich |
cornish_pug
Rich E wrote: simongti6 wrote: Rich E wrote: I think you've got confused somewhere. You can't adjust the height on the drivers side without removing the torsion bar on the drivers side. When you say the torsion bar is 15mm lower do you actually mean the ride height is 15mm lower? Yes drivers side sits 15mm lower when the car is on the ground than the n/s. It always has done since i've owned the car As noted, many cars left the factory with a small difference in ride heights but 15mm is excessive and unlikely to be due to assembly tolerances. I've just looked back at your older posts and given that you've posted in an older thread that you have arch rubbing on both sides I would say the trailing arm bearings have collapsed. Those older posts where for my old 306, plus the last car had 17's where as this one is on cyclones. ________________________________________ Team Diesel |
wheels wont make a difference.all the beams I've lowered have sat within a MM. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Rich E
simongti6 wrote: Those older posts where for my old 306, plus the last car had 17's where as this one is on cyclones. So you've had exactly the same problem with two different cars in the space of 2 months? Clicky Either way, with the limited information given my diagnosis remains collapsed beam bearings. What are the camber angles like? Heavy negative camber (the wheels angling inwards at the top) will confirm collapsed bearings. ________________________________________ Rich |
budgie
Newbie Location: loggerheads Registered: 30 May 2011 Posts: 15 Status: Offline |
will anyone do my torshin bar its a 306 hdi will pay dont worry about thatjavascript:smiley(' ')________________________________________ 306 powwwwwwerrrrrrrrr |
mike rallye
Seasoned Pro Location: mold Registered: 03 Sep 2008 Posts: 1,618 Status: Offline |
have you sorted this now budgie? |
