Author Subject: Brake squeal solved[ish]
smegal
A few years ago someone posted up a link to some stuff that you put on the friction part of your pads to stop squeal.
Can anyone remember what it was?
Ex SC-6
Now in a Megane R26
Posted 20th Jul 2011 at 23:19
lotek
yeh copper grease... LOL
look on camskil or ebay and its mintex squeel stop or somethin like that.
Posted 22nd May 2011 at 15:42
smegal
Anyone remember what this was?
Ex SC-6
Now in a Megane R26
Posted 1st Jun 2011 at 00:56
YOU MAY NOW FELLATE ME.
Took forever to find the thread but it started to p*ss me off, and I couldn't stop looking.
This is the product, and this is the thread.
Damn, that was not fun.
Posted 4th Jun 2011 at 08:21
smegal
I now owe you fellatio. I could NOT find that f*cking thread.
Ex SC-6
Now in a Megane R26
Posted 5th Jun 2011 at 00:27
cwspellowe
Does anyone know if that stuff works? The blurb says it targets air pockets in the friction material,I thought the squeal was resonance from the disc?
Bye bye Sundance Kid Sad
Posted 5th Jun 2011 at 00:26
Pads are always slightly porous, even after pyrolysis, I'd guess it just sets up as a resin in the pores and makes the pad structure slightly stiffer with more internal damping.
Absorbs a little of the resonance but more importantly problem shifts the frequency it occurs at.
Posted 5th Jun 2011 at 02:22
iplay
to reduce/eliminate squeal bevel the front and rear edges of the brake pads without touching the inner or outer edges. Add some copper slip behind the pads. Clean up the face plate with a little copper slip around the hub to seat the disc.
Could a slightly worn wheel bearing make brakes? squeal?
Posted 6th Jun 2011 at 04:50
Tried that all on my Brembos, didn't make a blind bit of difference.
Posted 6th Jun 2011 at 15:02
smegal
When I am not getting bent over by my exams I'll try and source some of this.
I have temporarily quietened my brakes using:
This
These
I also removed the rust and ground the lip off the discs and filed a tiny chamfer on the leading and trailing edges of the pads.
Let's see how long they stay quiet for.
Ex SC-6
Now in a Megane R26
Posted 20th Jul 2011 at 22:03
smegal
If anyone else wants any there are group discounts here
Ex SC-6
Now in a Megane R26
Posted 20th Jul 2011 at 22:05
24seven
I had chronic brake squeal on the 206 GTi 180 brakes a I fitted to my 306 XS for a bit, and we've had the same trouble on the uni Formula Renault we're running. Both times it was a manufacturing defect in the pad where they contact the sliders. On the Renault there's a U pin that goes through the calliper and holds the pads in place. There were burrs in the edges of the holes this pin goes through. On the 306 the shoulders of the pads where they slide were burred as well. It's always worth taking your time and making an effort to clear any dirt/debris/rust away from the sliders, make sure they're as smooth and flat as possible then put a thin smear of copper grease on them only where the pads are actually in contact with them (otherwise they collect dirt and dust and the grease just makes things worse) before the pads go in.
Posted 21st Jul 2011 at 02:36
