Author Subject: engine rebuild parts
clen666
Will be removing the 6s engine and stripping it down before rebuilding in the near future, so I want to make sure I have all the necessary bits and pieces before I start.
Could someone please list the small parts that I might overlook, for example core plugs and various seals, that are worth replacing while its in bits?
Team 'unintentional rat look'
Posted 22nd May 2011 at 17:26
clen666
Bump
Anyone?
Posted 26th May 2011 at 01:43
allanallen
Get the full pug gasket set which contains everything seal wise you need bar the head gasket.
I've never bothered changing the core plugs.
Then you'll want;
head bolts + washers
Main bearings
Big end bearings
Possibly thrust bearings
Piston rings
Cambelt kit
Waterpump
Thermostat
Throttle body gasket
Rtv/silicone
A couple of oil filters
Oil for rebuild + oil for running in
Any bolts/nuts/clips etc you break when stripping the engine.
Make sure your fully tooled up for the job. You'll want a decent torque wrench and piston ring compressors as well as the normal tools.
Hth, al
Facebook
Posted 26th May 2011 at 02:10
clen666
Great, thanks for the advice Allen Thumbs up
Posted 26th May 2011 at 20:47
ben306
Ive just done this, should be a near complete list within my project thread
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 26th May 2011 at 21:21
clen666
Ah ok thanks Ben, will take a look at that now
Posted 26th May 2011 at 21:31
chris with a pug
It will be worth getting a tube of Graghogen to coat the bearings when you put that together
Posted 26th May 2011 at 23:49
clen666
Thumbs up noted, thanks Chris.
Posted 27th May 2011 at 00:44
Just buy my rebuilt engine Whistle LOL
Posted 29th May 2011 at 15:55
Rich E Forum Admin
I'm not sure if you get valve stem seals in the kit or not, so check that.
Don't forget the machining work either. You'll want to get the block and head faces skimmed and the bores re-honed.
Oh, and get the flywheel re-faced too.
Posted 29th May 2011 at 16:04
allanallen
Stem seals are in the Peugeot gasket kit
Facebook
Posted 29th May 2011 at 18:09
clen666
Thanks rich, my plan is to get the cylinders rebored to 87mm and will be purchasing one on richw's flywheels eventually
Posted 29th May 2011 at 21:08
Rich E Forum Admin
Ah ok, I didn't realise you were boring out and changing pistons.
Unless you plan to fit the engine with the billet flywheel I'd get the standard one re-faced anyway. It won't cost much and I'd be annoyed driving a car with a nice rebuilt engine with a juddery clutch pedal!
Posted 29th May 2011 at 22:06
clen666
LOL yeah that would be annoying!
In no rush to build it so will be putting everything on in one go
Posted 29th May 2011 at 22:18
