i have had a look through some threads but cant find my question
please help
lots of love knoxie
ex S16 (K.I.A
) GTI 6
TEAM more scratches than an emo kid
TEAM BLACK
but wishing it was bianca white
displaying posts 1 to 25 of 36
| Author | Subject: cant get cat off mani... |
knoxie
Regular Location: harlow Registered: 11 Jul 2009 Posts: 400 Status: Offline |
as the title says i cant get my cat from my mani off, tried undoing the 10mil nut from the spring loaded bolts (not sure of the real name) but it just spins, do you have to have a spanner on the top of it aswell? if so how do you get to it as i can only just get my finger onto it i have had a look through some threads but cant find my question please help lots of love knoxie ________________________________________ ex S16 (K.I.A ) GTI 6 ![]() TEAM more scratches than an emo kid TEAM BLACK but wishing it was bianca white |
footah212
Senior User Location: Paisley Registered: 16 Sep 2010 Posts: 861 Status: Offline |
You need someone to hold the top of the bolt from the engine bay. Trying to do it all from the underneath is a nightmare.Passenger side 1 is easier to get to than the drivers side. You will have to sqeeze your hand down the back of the manifold to get to the drivers side bolt so make sure the engine is cold. Hope this helps ________________________________________ Phase 2 Blaze GTi6PS3 - Black Ops 2 Engine crane for hire Renfrewshire |
Yes you do. Need to feed it through, it's a right fiddle.________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
smegal
10 (or 11)mm spanner on the top too.________________________________________ Ex SC-6Now in a Megane R26 |
ian7675
Techno Viking Location: Gloucestershire Registered: 12 Oct 2007 Posts: 6,068 Status: Offline |
This is a job I did once...and vowed never to do it again. It's a tricky job to do ________________________________________ Less than 24 hours to go! |
knoxie
i have real fat hands thanks for the help guys i'll see if i can get to it ________________________________________ ex S16 (K.I.A ) GTI 6 ![]() TEAM more scratches than an emo kid TEAM BLACK but wishing it was bianca white |
Gilsey's very good at doing them too. He rocked up to mine to swap one off his old car onto his new car so ended up doing 2 at once. He seemed happy though.________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
smegal
Once you get the knack it is ok. IT just takes a lot of fiddling the first time. I used LOTS of extension bars and did it with a ratchet through the subframe and a spanner on top.________________________________________ Ex SC-6Now in a Megane R26 |
thugpuggin wrote: Yes you do. Need to feed it through, it's a right fiddle. How would you know? |
I do it from underneath on my back. left arm up around wishbone and anti roll bar, other over rack. I use a 6sided 3/8 on the top to get good grip, and then a 10mm socket on the bottom. I advise getting the sockets on correctly, then go guns blazing until undone. once the spring loosens and the cat drops, you lose easy access to the head of the bolt. If you round it off, nut splitter through spring works. Good luck________________________________________ ![]() |
6 sided socket or spanner is the way forward. A lot less likely to round off then. Easier underneath I thought. Before you say anything Ash yes I have done this quite a few times thank you very much ![]() ________________________________________ Nothing to see here |
ryans6
Junior User Location: Gillingham Registered: 05 Oct 2010 Posts: 92 Status: Offline |
Cut thmem or snap the bolts, then just replace them.________________________________________ BLACK 6 |
bennn
Seasoned Pro Location: Shrewsbury Registered: 05 Sep 2008 Posts: 2,705 Status: Offline |
I went from underneath last time, but had the benefit of using a proper car ramp which made it quite easy to see what i was doing.________________________________________ Cherry Red 306 HDIChampionship White Integra DC5 Type R |
ian7675
Did you get the fitting kit with the new cat? ________________________________________ Less than 24 hours to go! |
knoxie
Nothing wrong with the cat mate I'm putting a decat on ________________________________________ ex S16 (K.I.A ) GTI 6 ![]() TEAM more scratches than an emo kid TEAM BLACK but wishing it was bianca white |
ian7675
Did you get a fitting kit with the new DE-cat? ________________________________________ Less than 24 hours to go! |
knoxie
Nope 'twas a second hand jobbie ________________________________________ ex S16 (K.I.A ) GTI 6 ![]() TEAM more scratches than an emo kid TEAM BLACK but wishing it was bianca white |
knoxie wrote: Nope 'twas a second hand jobbie FAIL,best get ordering a kit then |
ian7675
I've obviously failed in my question, did you get a new fitting kit, irrespective of what you are fitting?It's not recommended to use the old bolts and ring gasket on a new cat, old cat, new de-cat or old de-cat. You can get them from Peugeot for about £13 iirc. ________________________________________ Less than 24 hours to go! |
^ Nearer £20. Last one I bought about 4 years ago was £18 something. Peugeot didn't have it in stock, so I got one from Citroen, which was actually cheaper yet in the same PSA packet.________________________________________ ![]() |
knoxie
Not had time to have a look today, been a busy bee ________________________________________ ex S16 (K.I.A ) GTI 6 ![]() TEAM more scratches than an emo kid TEAM BLACK but wishing it was bianca white |
ian7675
That's just crazy, £20 for literally a bag of bolts and a ring ________________________________________ Less than 24 hours to go! |
smegal
The pattern ones are much cheaper but inferior quality.________________________________________ Ex SC-6Now in a Megane R26 |
To be fair for the hassle of fitting it, do it once, and do it properly with a genuine Peugeot one. Buy cheap, buy twice.________________________________________ ![]() |
ian7675 wrote: That's just crazy, £20 for literally a bag of bolts and a ring £21.56 actually. ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
