Author Subject: running problems after gasket change
gt-aiii-six
I have recently had my head gasket changed and also replaced the head due to my last one being cracked and eroded badly. the head was skimmed before fitting and its had new head bolts.
since it has been done i have got a few problems
1. slight knocking noise from head (gets worse when warm)
2. when warm car will not idle when slightly revved
3. when warm it struggles to start. first sound like no compression then after a few seconds it judders and catches but struggles to idle (99% of time just cuts out)
any help would be great as to why i have these problems
cheers
Posted 9th Jun 2011 at 20:35
ian7675
Techno Viking
Where was it done?
Less than 24 hours to go!
Posted 9th Jun 2011 at 20:41
gt-aiii-six
head was skimmed by south wales pistons. the rest was done by a mate of mine. he has alot of experience with engine work but its the first gti-6 he has done lol
Posted 9th Jun 2011 at 20:48
ian7675
Techno Viking
Maybe he's timed it up wrong as I hear they're not the easiest car or maybe too much was skimmed off. I'm no expert but hopefully someone more qualified will be along shortly....
You could try sending a PM to mechanical_repairs.
Posted 9th Jun 2011 at 20:55
gt-aiii-six
funny enough we were talking about timing aswell. another symptom aswell is when driving, there is lack of power when throttle is pressed its fine for normal driving but when pulling off it lacks the normal response.
Posted 9th Jun 2011 at 20:59
lotek
timing, valve piston contact as result
Posted 9th Jun 2011 at 21:02
gt-aiii-six
that sounds quite possible which could explain the no compression sort of sound on starting
Posted 9th Jun 2011 at 21:06
Sounds like a fantastic garage. Must let them near my engine sometime.
Posted 9th Jun 2011 at 21:59
gt-aiii-six
it wasnt done in a garage. it was done on my mates driveway. his dad is a mechanic and he does it as a hobby. he completly rebuilt his c2 vts engine from the ground up and fitted throttle bodies. and its rapid. he also done a few engine transplants so i do trust him. i think it must be the timing out because all of the symptoms seem to lead that way. cheers guys will keep posted
Posted 10th Jun 2011 at 00:55
