displaying posts 26 to 48 of 48
Pages (2): 1 [2]
Author Subject: Feel like crying lol
davedgti6
Get a sniff test/and or compression test done on it to confirm head gasket is leaking again, if so you will have to take it apart again and determine why it is not sealing, only way I'm afraid Sad
Posted 12th Jun 2011 at 19:00
davedgti6
l8un08 wrote:
Hmm I'm not sure il upload a picture now! Surely a guy with 12 years experience couldn't put the wrong gasket on??
Sounds unlikely but we all make mistakes, I have put brake pads in wrong way around (metal to metal) and also put a thermostat in back to front on a ford engine Doh heated up fast though
Posted 12th Jun 2011 at 19:04
l8un08
thats the old gasket
bloooobirds
Posted 12th Jun 2011 at 19:28
l8un08
also.....if the head went in the first place something must have caused it too or are they wear n tear?
maybe whatever caused the head to go the first time hasnt been fixed....radiator or waterpump or something?
bloooobirds
Posted 12th Jun 2011 at 19:31
davedgti6
they just go from old age or the car overheats, has the temp gauge been in the red at all?
Bigger pic, someone will know what engine this is off,
Posted 12th Jun 2011 at 19:38
l8un08
the car reached red once when i had it ticking over outside the house but then i turned it off straight away.
bloooobirds
Posted 12th Jun 2011 at 19:42
Should've gone for a drive, the cool air going through the rad would have been more beneficial than switching off and letting all that heatsoak from the exhaust cook itself to death.
Posted 12th Jun 2011 at 20:07
l8un08
When driving the car never reaches red! It stays at about 102ish n stays there! But if I pull up n leave it then it pushes towards red and then engine off and water spills out of the overflow pipe Sad
bloooobirds
Posted 12th Jun 2011 at 20:00
l8un08
Thanks anyway guys
bloooobirds
Posted 12th Jun 2011 at 21:14
davedgti6
Post #35
l8un08 wrote:
Thanks anyway guys
No problem Thumbs up hope you get sorted and let us know how you get on Smile
Posted 12th Jun 2011 at 21:23
l8un08
Post #36
What should I do? Scrap or fix? Just paid 250 to get head skimmed crack tested etc! It's an R reg 306 glx 1.8 with 12months Mot 6 tax!
62,000 miles with full service history
bloooobirds
Posted 12th Jun 2011 at 21:26
l8un08
Post #37
What would any of you do?
bloooobirds
Posted 12th Jun 2011 at 22:14
davedgti6
Post #38
First confirm that's its gone again -sniff or compression test, find out why it overheats when its ticking over, are the fans operating correctly?, if its deffo gone find out why, head should be ok as you had it skimmed and pressure tested, next whip the head off, examine gasket, confirm its the correct one, next examine gasket again to see if its clear where the breach between the water jacket and combustion chamber is, next check cylinder liner protrusion and liner levels are within tolerances, if they are check there are no cracks in the liners themselves (had this once in a 309), do you have water in the oil? if so maybe change liner seals, do use a good/genuine headgasket and new headbolts greased and torqued up correctly,
I am sure your mechanic will at least test to confirm the headgasket has gone again, and strip the head off to see why, this will not take him a lot of time,
Then once you know what the problem is you will have to judge whether its economical to fix or source another engine, you wont get much for scrapping her,
You might be lucky it might be an airlock with a combination of an overheating issue and/or a faulty radiator cap, Smile
Posted 12th Jun 2011 at 22:40
l8un08
Post #39
So I have a good chance that the head hasn't gone again as I had it skimmed and crack tested about 2 days ago Ye! In answer to your comments on what to do, thanks il make sure he's checked everything before I make any silly decisions as it's such a smooth drive and has so many miles left in her! Passed MOT 2 weeks ago failed on 1 tyre! I know he had to get new bolts as he didn't wanna snap the old ones as they were badly corroded!
Just wanna thank you for all the help! This site is easily the best on net!
bloooobirds
Posted 12th Jun 2011 at 22:47
paul_13
Post #40
Just don't say you wanna put a 6 engine in or it'll turn into the worse forum on the net for you Wink
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 13th Jun 2011 at 04:20
cwspellowe
Post #41
It stays at 102 under normal driving? That's not right! Doubt it's the headgasket again but your so called experienced mate doesn't sound too clued up on how to bleed the coolant never mind a headgasket change!
Personally i'd check the thermostat if the normal operating temp is so high. That or an airlock
Bye bye Sundance Kid Sad
Posted 13th Jun 2011 at 04:41
cwspellowe
Post #42
double post
Posted 13th Jun 2011 at 04:43
l8un08
Post #43
Hey guys! The car had a brand new thermostat on when head was done! My mate said something about the thermostat looking weird and having no lil hole in it! So we took it out, I've been driving round all day without it on and car hasn't reached 90! And also no water is being lost!
Should I go to main dealers for a thermostat?
bloooobirds
Posted 14th Jun 2011 at 00:21
l8un08
Post #44
Also do you think that's my problem fixed?
bloooobirds
Posted 14th Jun 2011 at 00:22
Post #45
probably, if its not doing it now the thermostat is removed then i would say thats what was wrong
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 14th Jun 2011 at 01:22
Post #46
Could be, I've had a brand new stat that did'nt work before. Get a genuine part and try again, I would'nt be tempted to leave the stat out, as it will take ages for your engine to reach the correct running temperature and will wear out faster.
Posted 14th Jun 2011 at 01:26
cwspellowe
Post #47
Was I right? Shock
Posted 14th Jun 2011 at 02:17
l8un08
Post #48
cwspellowe wrote:
Was I right? Shock
Haha I guess so mate!
How much for a genuine stat from peugeout guys? Thanks again
bloooobirds
Posted 14th Jun 2011 at 03:29
Pages (2): 1 [2]
