Author Subject: Fan switch or temp or head or what?
l8un08
Right guys have had an ongoing problem with my pug 306! Headgasket got done and since then the car is fine but not if it's in traffic for a long time! The fans kick in at about 103?? Surely that's way to high and even then it doesn't push temp down! I then turn off engine and as expected water out of overflow pipe! Am I looking at a new fan switch or temp switch or what? Thanks guys
bloooobirds
Posted 15th Jun 2011 at 23:10
l8un08
Also just to add the fan is very inconsistent about coming on! Also when it goes over 100 I tend to turn the car off so don't know Exatly what temp fan kicks in! If it does
Just a quick update I have now run the car till the fans kicked in at about 103!! I noticed only the left side spinning!! Is this normal! Thanks
bloooobirds
Posted 15th Jun 2011 at 23:44
I think the first fan should kick in at about 90 odd then the second at 103ish, so looks like your first fan isn't working.
Posted 15th Jun 2011 at 23:56
l8un08
Ye that looks and sounds right! The fan is high speed when kicks in so I'm guessing the low speed fan is nackered! Any suggestions what to do or I need?
bloooobirds
Posted 15th Jun 2011 at 23:58
Never done it myself, see if you can get to the connections and see if the first fan is getting 12v or not, it should come on when you unplug the brown temperature sensor plug.
Check obvious stuff like stones stuck in it, if it's getting volts but not blocked or turning it'll be new fan time.
Posted 16th Jun 2011 at 00:05
l8un08
Hm okay man! Doing my head in!
bloooobirds
Posted 16th Jun 2011 at 00:30
l8un08
How do I check if the fan is getting volts? Also Isit just a case of pulling the brown plug out??
bloooobirds
Posted 16th Jun 2011 at 00:49
Try the brown plug first, see if it comes on. If it doesn't, you'll need a multimeter to check the voltage.
Have a search on here, you'll find everything you need.
Posted 16th Jun 2011 at 01:03
l8un08
Took the plug out and only one fan came on! Seems like only the high speed fan is working! Is this common?
bloooobirds
Posted 16th Jun 2011 at 17:29
It is according to the number of threads already on the subject Wink
Just search for "fan not working", you'll find all the suggestions and fixes in there.
Posted 16th Jun 2011 at 17:32
More than likely to be the bitron unit, which controls the fans.
  • Posted 16th Jun 2011 at 17:45
    l8un08
    Do all 306's have a bitron unit?
    bloooobirds
    Posted 16th Jun 2011 at 17:58
