Author Subject: bonnet stuck closed
shutie
I have searched for other problems like this but what is the easiest way to open the bonnet apart from using the usual handle as the cable has somehow detached...? Sad
cheers
Posted 22nd Jun 2011 at 00:32
fozzy_255
Stick your hand up from underneath car in-between radiator and bumper and pull what the wire would be attached to
Posted 22nd Jun 2011 at 00:38
shutie
i did try that but it was too tight for my arm?
Posted 22nd Jun 2011 at 00:45
fozzy_255
If there is any cable left just pull on it, it mught be easier to get to. Im afraid thats the only easy way. well without taking the bumper off that is
Posted 22nd Jun 2011 at 00:49
cwspellowe
Smash the grille up and undo the two bolts holding the catch on Dunno
Bye bye Sundance Kid Sad
Posted 22nd Jun 2011 at 00:55
not sure if its possible on a Rallye, but on the early TD's you can reach up through the engine bay to behind/above the r/h headlamp and tug on the wire where it has a Joiner.
Could always remove the bumper and fish about under the grille, or break the grille.
shutie
thanks guys, i will have a look around the headlight, i wasnt entirely sure where the cable ran. Might just have to take the bumper off then. Wink
Posted 22nd Jun 2011 at 00:57
cwspellowe
It's clipped up inside the slam panel and then along the wing Thumbs up
Posted 22nd Jun 2011 at 02:53
mattgti6phase2
Sounds to me like the the clip that holds it into the slam panel has broke hence why it's slack. The actual cable should still be in the mechanism.
Cable tie the clip into position and job done. As for getting at the cable I detached mine from the leaver inside and pulled it hard Wink then it released.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 30th Jun 2011 at 12:31
shutie
the release under the steering wheel was opened fully with no give whatsoever, i stuck it down to 'my' mechanic who has just managed to get it opened this morning without taking off or breaking anything thankfully. I will speak to him later to find out how he managed it.
But thankfully after that is fixed the rallye is now nearly fixed after her little missanter in a steel road barrier (6 months ago) Blush Big grin
Posted 30th Jun 2011 at 14:21
russbez
haha woops Razz
emm prob not best post how he done it on public forum Big grin
glad to hear you got it sorted, good luck replacing the cable if its snapped, mine was a total b*tch
My Rallye project thread
Posted 30th Jun 2011 at 14:53
shutie
russbez wrote:
haha woops Razz
Cry dont say that..... although... i wont have to work with it Razz
Posted 1st Jul 2011 at 00:20
