Are they available to buy from Peugeot? Or is it a scrapyard cut of and solder job?
| Author | Subject: Engine wiring loom plugs |
I have a broken engine wiring loom plug. It has snapped where the wire goes into the connector.Are they available to buy from Peugeot? Or is it a scrapyard cut of and solder job? ________________________________________ ![]() |
ablister
Senior User Location: fife Registered: 30 Oct 2005 Posts: 522 Status: Offline |
if its the big multi plug connector that joins main loom at OS chassis rail then you can buy them from peugeot but they are really expensive (possibly £70+). It's basically the same connector that is used on the door wiring loom repairs but a straight connector instead of the 90 degree one________________________________________ 306 rallye, Richard Longman enginerc10gt |
It's just a connector for what I believe is for oil level/temp or whatever it is.It's attached to the sump IIRC and light blue. I have got a couple of light blue plugs from a Saxo which have the same purple centre inside, so will hope one of them fits the same way. ________________________________________ ![]() |
ablister
yeah, those connectors are found on alot of different peugeots. Best to go to scrappy and cut a similar one off. ________________________________________ 306 rallye, Richard Longman enginerc10gt |
pugjim
Seasoned Pro Location: Sheffield Registered: 11 Mar 2007 Posts: 1,380 Status: Offline |
Im sure somewhere on the megasquirt sites you can get them new with the crimp on pins. I got some when i built a loom for a dta. |
ravemercer
Regular Location: kent Registered: 18 Jan 2009 Posts: 422 Status: Offline |
asked peugeot about a plug for a icv was told no they just sell certain bits of the loom tho |
