Author Subject: Changing my beam
peetypug
A rear beam mount is on the way out on my rallye
One side has been replaced but the other has been knocking a little
I've got a phase 3 beam that's ha all the mounts changed, the problem is they are different
The rallye has the compensator, but this beam doesn't.
Will it be fine to swap it without the compensator?
Thanks in advance
Cherry rallye - DOB Thursday 29/04/1999
Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
roland rat wrote:
You sir either live for the 6 or have a mental retardation to still be repairing this!
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
Posted 28th Jun 2011 at 03:44
fit the compensator to the replacement beam, you can leave the bracket parts and front beam mounts on the car and remove the tube on its own without disturbing the brake lines
Posted 28th Jun 2011 at 04:00
peetypug
Ayup WP
Would it be ok without it?
I'm assuming that there's no difference in the beams other than the compensator and if the phase 2 braking system is the same as phase 3 bar the compensator then i will just go with that as is
The compensators tend to seize over time anyway
Posted 28th Jun 2011 at 04:21
peetypug wrote:
Ayup WP
Different brake set up on later cars,hence no compensator.
Something to do with ABS,independant brake system rings a bellUnsure
PS,are those VTS torsion bars off yet???Whistle
Posted 29th Jun 2011 at 04:00
peetypug
Your right kev, abs unit is different
I aint touched the Vts beam yet (been to busy with the shedrallye) you can take the whole thing for the price if the torsion bars if you want to?
It will have no shocks or calipers though
Posted 1st Jul 2011 at 04:15
Ok,price of torsion bars might help though!!!!LOL
Posted 1st Jul 2011 at 04:30
