Author Subject: Can someone tell me what this is?
marco gti6
Hello fellow members i just stumbeled across this nice looking piece of kit on a french 2nd hand site.
I am aware that this is no sequential GB, bu could someone be so kind to explain me how this is supposed to substitute the original gear lever?
clicky
Thanks for looking Wink
Posted 30th Jun 2011 at 19:09
rallyeash
that won't work with a H pattern standard gearbox. need a sequential GB Yes
309 3dr K20 Type R
Posted 30th Jun 2011 at 19:14
c_j_m
TBH it looks to work in a very similar way to the cable operated boxes that come on the newer pugs.
It would still have the standard gear layout, but with a short throw?
Posted 30th Jun 2011 at 19:19
marco gti6
The description clearly says this can be used on the standard 6 speed gearbox. I was just wondering how this would take over the part of shifting through the H patern of the GB.
Still would look smart :cool
Posted 30th Jun 2011 at 19:26
marco gti6
Just found this on the manufacurer's site:
http://www.bacciromano.com/index.php?p=prodotti&l=eng&cat1=24&cat2=47&mar=6
Hyper Crazy 13650€ for a sequential GB ready to throw in.
Posted 30th Jun 2011 at 19:33
clen666
Does look like the linkage on the right of the unit works from the left/right movement of the stick
Cool
Team 'unintentional rat look'
Posted 30th Jun 2011 at 19:32
bobdylan_55
linkages look very similar to the ml5t ones...
309 GTi6-T
Posted 30th Jun 2011 at 19:45
yeap, there's lots of BE4 boxes using cables too, but that kit on the first link is designed directly for a standard H pattern 306 gearbox.
have seen similar in a group A Xsara last time I was in belgium.
Posted 30th Jun 2011 at 23:55
marco gti6
So this lovely bit of kit transforms the Hpattern box in a up/down shifting lever? Seems pretty cool Cool
Posted 1st Jul 2011 at 01:08
c_j_m
I doubt it tbh, will still use the standard gear layout I'd have thought.
Posted 1st Jul 2011 at 01:13
can't see how left to right movement is achieved ?
only back and fourth ?
Posted 1st Jul 2011 at 01:17
gtylerroberts@manx.net
If you look closely at the mounting of the gear lever it allows movement side to side and has a drop link to transfer to the gearlink cables like clen said
Posted 1st Jul 2011 at 03:41
yeah, works exactly as std H patten, just taller less play and shorter more precise shift, also engine movement will not move the stick about
Posted 1st Jul 2011 at 04:15
