Author Subject: Rear Beam Rebuild.
techdw
Who are the main people that can supply me with a rebuilt rear beam so I can do a simple swap of beams on the car rather than taking mine off and repairing it.
I have Pm'd jord294 as I know he does them but not had a reply yet.
I want one thats had bearings, Seals, shafts on the trailing arms replaced if need, then I can bolt it on with my solid beam mounts and so on.
Cool
Posted 5th Jul 2011 at 19:33
cwspellowe
+1 i'm looking at doing this too, really can't be f*cked rebuilding my own beam. Seen a few 205 and 309 beam specialists on the googleweb and i'd assume the 306 is laid out pretty similarly..?
Bye bye Sundance Kid Sad
Posted 5th Jul 2011 at 19:35
techdw
Yeah its easier just to slap a fresh built painted on there.
Posted 5th Jul 2011 at 19:38
jord294
the downside i have with supplying freshly painted rebuilt gti6 beams, is that because the abs sensors won't come out in one piece, i can't get the arms done Sad
techdw - sorry i didn't pm back
i can supply fully repainted beams (just without abs sensors)
e.g
fully rebuilt powdercoated gti6 beam, using genuine parts bearings, seals, new trailing arm shafts, mounts, disc protectors and new abs sensors will cost nearly £700
still half the price a main dealer would charge
unpainted rebuilt beams cost from £280
i can supply vts bars, shocks, solid mount kits etc, but obviously the price increases
current climate tells me people can't justify spending £££s on just one part of a car
although, 205 gti owners are willing to spend good money on axles i can supply
Posted 5th Jul 2011 at 20:04
dhampton
A refreshed beam is money well spent. Wouldn't bother with making it pretty though!
Clio 182 FF 306 Rallye (track) 306 Gti-6 Megane R26 Clio 172 Cup (track) 106 Rallye S2 (track) 306 Rallye Saxo VTR 106 Zest2
Posted 5th Jul 2011 at 20:23
cwspellowe
Jord how much would we be talking for a rebuilt beam, unpainted, 40mm lower with VTS bars and no shocks?
When you say you can't do the trailing arms, what do you mean? Surely you can remove them and replace the bearings and shafts?
Posted 5th Jul 2011 at 21:02
jord294
in a recent telephone conversation i have had, i have explained that it is harder NOT to supply a beam with mounts, as ideally the bolts need to be tight to set the dummy shock properly
none of my beams come with shocks (unless buyer specifies) and as i only have the one set of vts bars, i would have to charge a similar cost to new ones
i can do trailing arms but if a customer wants them powdercoating, then new abs sensors will be needed
not many people are willing to spend £80 each
Posted 5th Jul 2011 at 21:23
glenn_addo
you can get abs sensors from peugeot for under £100 for both left and right. cheaper than all motor factors
Posted 5th Jul 2011 at 21:27
jord294
i stand corrected Blush
they have dropped in price compared to about 12 months ago
£98 inc vat from main dealers for 2 Wink
Posted 5th Jul 2011 at 21:33
glenn_addo
Yeah still expensive but cheaper than motor factors which shocked me when I needed some a few months ago.
Posted 5th Jul 2011 at 22:20
