Author Subject: cutting out when hot
nicks306gti6
Hi all
I know this has been been posted many times but my problem is very specific.
Once the car gets above 90 on the temp gauge, as i come up to a junction or change down, depress the clutch pedal, the revs fall to about 400/500 rpm and the car either struggles to get back up to the normal 800 rpm hot idle or just cuts out. The car starts fine again and repeats the above time and time again. parking the car when hot is almost impossible.
If i leave it to cool it's fine again until hot then repeat above.
The car performs faultlessly in every other respect.
Just fitted a brand new marelli stepper icv and no change.
I am keen not to have to go through changing sensor after sensor etc so wonder if anyone else has had the same SPECIFIC problem as i have and has managed to cure it by changing or fixing what ?
cheers all
Nick (tearing my hair out)
306 gti-6 1998 80k totally standard
NICK F
Posted 14th Jul 2011 at 03:03
Lecktorious
aka G.
Have you got an open air filter fitted?
'98 Nile Blue 306 GTi 6
Posted 14th Jul 2011 at 03:06
nicks306gti6
standard air filter, standard air box
NICK F
Posted 14th Jul 2011 at 03:09
paul_13
Did you reset the ecu when you fitted the new ICV. It'll keep messing up until you do.
Look under the FAQ section for how to reset ECU
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 14th Jul 2011 at 03:22
nicks306gti6
yes indeed. reset the ecu surgically !!
NICK F
Posted 14th Jul 2011 at 03:25
paul_13
Ok believe ya Razz
ECU temp sensor is the next port of call really, it's the green sensor out of the three on the thermostat housing
Take it out and give it a clean, see if that makes any difference. Might be caked in shite, mine was. I sourced a new one in the end as I didn't like the look of it.
Again will require a ecu reset
Posted 14th Jul 2011 at 03:28
lotek
ecu reset wont solve icv
you need to keep turning ignition on wait and turn off without starting Yes
this sets the Stepper motor position Smile
Posted 14th Jul 2011 at 03:29
paul_13
^ I've solved a problem with ICV on mine before by reseting. Hovis has aswell.
Didn't know about that for setting the ICV. You learn something new everyday Big grin
Posted 14th Jul 2011 at 03:34
nicks306gti6
ordered a new coolant temp sensor today, green one as you suggest so i'll give that a go when it arrives.
will all the coolant pi55 out when i remove it or will a cold thermostat being closed limit that ?
cheers
NICK F
Posted 14th Jul 2011 at 03:39
paul_13
p*ss out Smile
Don't forget to bleed it.
You'll need a coke bottle with a bit of electrical tape or similar around the top. Press this on to the expansion tank opening. (best with 2 people) open up the bleed screws on the thermostat housing and matrix hose. (may of missed one)
Squeeze bottle to push the water into the system wait for coolant to come out of bleed screws then nip them up.
Posted 14th Jul 2011 at 03:45
nicks306gti6
ah, i see LOL
cheers.
will report back once cts fitted is fitted.
NICK F
Posted 14th Jul 2011 at 03:52
pugjim
Theres also a bleed screw on top of the rad. To minimise fluid loss just put your thumb over the hole when you take the temp sensor out and put the new one back in quickly.
Posted 14th Jul 2011 at 17:56
You won't lose much fluid if you are quick.
Posted 14th Jul 2011 at 18:17
smegal
Mine does this, and I suspect it's an earth that comes loose when the under bonnet temps are high.
Everything else is fine as shown by diagnostics.
Ex SC-6
Now in a Megane R26
Posted 14th Jul 2011 at 20:24
