displaying posts 26 to 32 of 32
Pages (2): 1 [2]
Author Subject: Another hesitation issue
swiftyboi006
Change the plugs then, sound like u need to, might be worth getting a compresion test as there could be a prob with tgat cylinder
Black p3 Love
Posted 12th Aug 2011 at 23:22
daddy5times
I swapped the coil from another cylinder to the 1 with the crusty sparkie .also put a new plug in it but it's still spores up this morning all others are fine !so can't be plug can't be coil any other ideas chaps? I'm gonna take it for a compression test on Tuesday .if compression was down on the cylinder wouldn't it always run like it's on 3 also wouldn't it idle rough ?thx
Posted 13th Aug 2011 at 17:16
daddy5times
no matter what I try the sparkplug is still getting sutted up .it's not the nearest one to thermostat but the one after .is there any thing else I can check??? Crazy
Posted 15th Aug 2011 at 01:29
sounds like headgasket
Posted 15th Aug 2011 at 01:40
daddy5times
oh sh?t how could i check this?
Posted 15th Aug 2011 at 02:12
daddy5times
doesnt use oil no oil in water or overheat????
Posted 15th Aug 2011 at 02:14
iplay
daddy5times wrote:
There seems to b a very small split in the pipe that joins the big pipe witch comes from the throttle body ???? .wondering if this could b making it worse
This will cause 100% of the symptoms you describe ...
Posted 15th Oct 2011 at 10:27
Pages (2): 1 [2]
