Author Subject: 2.1 + suoercharger
Is there any reason not to supercharge a 2.1 conversion, or is it even possible? Discuss
Am considering having that done tbh. After I refresh every last bit if suspension
Posted 10th Aug 2011 at 21:32
smegal
It depends on how high your compression ratio is.
Ex SC-6
Now in a Megane R26
Posted 10th Aug 2011 at 21:34
no reason why it can't be done, though with the power gains you get from just the standard 2.0 there's no point really.
Surely you would have epic torque though? Any educated guesses as to what you would end up power wise
Posted 10th Aug 2011 at 21:38
5% more than a 2.0?
Not a lot...
Posted 10th Aug 2011 at 21:40
So its a no then? Would it be more reliable? I.e under less stress when making the same power?
Posted 10th Aug 2011 at 21:49
Rich E Forum Admin
No, re-boring that far will increase the risk of engine failure.
You'll gain a little power and torque yes, but assuming you're taking about low boost it'll add about £1k to the cost (machining, pistons, mapping, etc.)
Posted 10th Aug 2011 at 22:07
indeed, you might as well go high boost if youre opening it up.
matty_rallye
If you were going to go to the extent of changing the crank then for supercharging purposes you would be better off going for the 2.1 td crank and getting almost 2.2 with 87mm pistons?
2.1 16v 306 Rallye.
Posted 11th Aug 2011 at 00:20
