Author Subject: HELP Please!
honestly3k
Dont suppose anyone has a front caliper carrier sliding pin with bolt close to Tring, herts and can help me out?!?!?!
Bolt going into the slider kindly snapped in half and half of it is still in the slider Sad
Posted 1st Oct 2011 at 13:59
6waysforward
local scrappy mate. iirc you can use the sliders from a 406 with the same size discs or failing that, a xsara or 306 etc.
Posted 1st Oct 2011 at 14:05
if there's a bit protruding you should be able to wind it out with some grips.
90% or so of 406's uses the same caliper btw.
Posted 1st Oct 2011 at 14:06
I managed to get one out the other day by twatting it with a hammer back and forth until it came loose Yes
Posted 1st Oct 2011 at 14:10
honestly3k
Have no transport to get to a5 salvage about 12 miles away. Found a bolt I can use but getting the half bolt out of slider isn't going well.....there's barely any thread protruding Sad
Posted 1st Oct 2011 at 14:12
Stick another bolt in and hammer the old one out?
Posted 1st Oct 2011 at 14:14
drill it oot Smile
Posted 1st Oct 2011 at 14:22
honestly3k
Drilling it out slowly...drill is low on battery lol.....got the small hole drilled.....I'm a tard...just found out I only needed to undo the carrier and not calipers anyway to get to the disc and pads. Doh
Posted 1st Oct 2011 at 14:27
honestly3k
Sorted! Drill ftw! Lesson learnt....thanks boys
Posted 1st Oct 2011 at 14:39
