Would like your guys input on this please, One wheel looks like its in more then the other, will check the offset of the wheels but they are ET15.
Is it my eyes or does it look different?
displaying posts 1 to 25 of 50
| Author | Subject: My Wheels |
techdw
Senior User Location: Kent Registered: 28 Sep 2010 Posts: 897 Status: Offline |
![]() ![]() Would like your guys input on this please, One wheel looks like its in more then the other, will check the offset of the wheels but they are ET15. Is it my eyes or does it look different? |
Hard to tell and might be the camera angle, but looks like the second one might have a bit more camber, which would be due to a collapsed bearing. I'd double-check the offset (what they're stamped with and measure them yourself) then check the camber. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
rikky
i think you should get rid of them wheels immediatelyto me ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
techdw
I am going to take the wheels off and double check later mate.Is the Camber ajustable on the rear? |
mr west
Senior User Location: herts Registered: 13 Sep 2010 Posts: 742 Status: Offline |
if it has negative camber on one wheel at the back it will be a trailing arm shaft bearing collapses asowain said, but they look pretty good to me, hard to tell from pics ________________________________________ white rallyecherry dead rallye s16 |
techdw
RIGHT wheel Rear![]() Left Wheel Rear |
techdw
Left Looks bent!?? |
yup, I'd get a new beam, likely to have slid against a kerb at some point in its life.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
techdw
What cost am i looking at for a new beam? |
depends how far you go, could be as little as £40 or so if you use your torsion bars and brakes and you just chuck it on and hope, or £150-£200 if you rebuild it whilst its off.*if you do the work yourself, its not hard but you will often need access to a press and often proper heat (oxy-prop/acetylene) ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
2nd hand unit with a bit of life left it in, £100-£120 with calipers.Chances are it could go the same way in time. Refurbed beams are a few hundred, but will have nwe bearings etc so will last ________________________________________ ![]() |
mark.evs
Senior User Location: Near Bridgend Registered: 21 Dec 2010 Posts: 527 Status: Offline |
U got a pic of the back of the car with both wheels in it? they look the same to me but the gap in the arch is making it look out. beams are anything from £100-£500. ________________________________________ My GTi6 track projectWhite Rallye project |
I'd take it somewhere and get them to measure the rear tracking, should be zero both sides.________________________________________ Membership expiring soon, get in contact on our new little forum project. |
techdw
mark.evs
Really hard to tell, if it is out it aint by much, like Owain said, get it 4 wheel aligned.________________________________________ My GTi6 track projectWhite Rallye project |
techdw
Yeah will have to get that checked. |
ballardpaul
Seasoned Pro Location: Croydon Registered: 22 Jul 2008 Posts: 4,135 Status: Offline |
Look identical to each other. ________________________________________ Phase 2 Blaze GTi 6 (Standard) SoldPhase 3 Supercharged China GTi 6 (249.8 BHP) Sold Phase 3 Supercharged Diablo GTi 6 (443 BHP)Sold Nissan 350Z (300 BHP) |
Jack the car up under the beam in the middle until the tyres lift slightly off the ground and see if they both lift at the same time________________________________________ ![]() |
Jack the car completely off the ground and place a chinchilla under each wheel. Lower the car gently and see if they both squeak at the same volume. Standard test. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
will130787
Seasoned Pro Location: Reading Registered: 24 Sep 2009 Posts: 3,933 Status: Offline |
Looked exactly like mine did which got progressively worse over time and one side started to 'collapse' after the beam had been 'rebuilt' 10k miles earlier by CG cars. My trailing arm was bent slightly and the beam was fuc*ked! Take the wheels off, check the offset on each and check for movement in each trailing arm! ![]() ________________________________________ Ex Astor 6 owner![]() Also an Ex owner of a Bianca 6 ![]() Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... ![]() Now driving Mk5 Golf GTTdi, mile muncher But still live for the 306 |
cwspellowe
Seasoned Pro Location: Calderbank Registered: 19 Jul 2009 Posts: 6,496 Status: Offline |
techdw wrote: Is the Camber ajustable on the rear? Yes, but not intentionally ________________________________________ Bye bye Sundance Kid |
techdw wrote: ![]() With the lack of wiper arm, spray paint on the number plate and the saggy hand brake cable these could all cause uneven weight distribution giving the effect of a f*cked car. ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
mechanical_repairs
will130787 wrote: Looked exactly like mine did which got progressively worse over time and one side started to 'collapse' after the beam had been 'rebuilt' 10k miles earlier by CG cars. My trailing arm was bent slightly and the beam was fuc*ked! Take the wheels off, check the offset on each and check for movement in each trailing arm! ![]() Yet another been rebuilt by carl but this is the first I hear of it! When the car was here Wayne it never looked like it had a beam issue. I would say it's best to rebuild now as finding a known good unit will be slim, if you do then you will also have to have the ride height adjusted again. Get it checked first, it may be nothing. Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
techdw
Cheers Carl. Yeah agree with you there mate, it all looked Okay.Will Check it first before I do anything. |
davewagon
Senior User Location: Corby / Northampton Registered: 21 Feb 2007 Posts: 889 Status: Offline |
What size are these alloys, looks good fit ! 15/16 inch? ________________________________________ Team: Moonstone GTI-6™Team: ian7675 wrote: Remember....a 6 isn't just a car, it's a part time job |
