Team Diesel
| Author | Subject: Rear shock |
cornish_pug
Regular Location: Marazion Registered: 18 Dec 2009 Posts: 368 Status: Offline |
What are the symptoms of a knackered rear shock?________________________________________ Team Diesel |
bouncyness, shite handling, understeer.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cornish_pug
The shock creaks very loudly when compressed and, once compressed it doesn't really come back up again ________________________________________ Team Diesel |
is that with the damper removed?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cornish_pug
welshpug! wrote: is that with the damper removed? No, on the car still. ________________________________________ Team Diesel |
More likely to be the beam siezing up, disconnect a damper bolt and see if it's the same.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
what phill said!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cornish_pug
Took the damper off today and the noise stopped when I lowered the swing arm onto an axle stand. The damper was fairly easy to compress with one hand but it was harder to de-compress. Not sure how the damper should feel! ________________________________________ Team Diesel |
But does the beam make a noise when you move the arm, and do the trailing arms extend properly?If you can compress and extend the damper by hand then that was not what was holding the suspension up. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
cornish_pug
phillipm wrote: But does the beam make a noise when you move the arm, and do the trailing arms extend properly? No it's pretty much silent in movement when I move the trailing arm up & down with the damper removed. With the damper bolted back on the noise comes back. I can feel it coming from the damper when I put my hand on it and jack it up & down. ________________________________________ Team Diesel |
atterz
Seasoned Pro Location: Stafford Registered: 18 Feb 2011 Posts: 1,134 Status: Offline |
Also scalloping of the rear tyres!________________________________________ owain wrote: A GTI-6 with a good dashboard and the seats down can outsprint an E46 M3 in July. |
