Author Subject: Everything going mental!!!
Rix13
Right have a couple of problems. The other night the tape player decided it wanted the code again, god knows why, just did. Put the wrong code in (my bad) and it just came up with 4 dashes on the tape player, so I thought i'd disconect the battery. This is where everything went wrong. Put battery back on and the hazards flashed really quickly, the tape player just doesn't work, clocks went all the way up and the clock/temp is now doing a funky dance. Played with some fuses and made it worse and wouldnt start. Narrowed it down to worn wires to the + on the batt which are getting sorted tomorrow and took the fuse out for the anti code start thingy to stop the hazards and the clocks have sorted them selves. Still have no tape player and the clock is just showing vertcial lines then horizontal lines. Any ideas?
www.eastcoastmodified.org
E46 318i tourer SE - Dog Car/Work horse
306 Gti - Track Project
Posted 3rd Nov 2011 at 17:59
judge dead
possibly a dodgey battery
Posted 3rd Nov 2011 at 18:03
greenbelt
There is a loose earth connection somewhere. Follow the wiring from the battery negative terminal to the earth point on the passenger side chassis rail. It is just below and in front of the battery box. Check it is done up properly. Do the same with the other earth point on the gearbox.
It does that when the battery is disconnected. Set the time to sort it.
Standard Black 6
Black HBSC6 Smoke
Posted 3rd Nov 2011 at 18:12
Rix13
Sounds like a pretty easy fix then, any ideas on the tape player?
Posted 3rd Nov 2011 at 18:15
greenbelt
Try the FAQ
Standard Black 6
Black HBSC6 Smoke
Posted 3rd Nov 2011 at 18:18
Rix13
ah cheers
Posted 3rd Nov 2011 at 18:34
The eight-track in my car started doing the same, so I just replaced it with a sweet gramophone boot install.
Posted 3rd Nov 2011 at 19:11
Rix13
Right can back with battery sorted along with cambelt and tried sorting the tape player out by putting the anti code fuse in. put it back in, tape player works along with central locking etc but the hazards keep flashing even when i start the car. Do i have to unlock the car with the key fob buttons to tell it i have the right key? becuase if so mine doesnt work lol
Posted 4th Nov 2011 at 16:59
That's actually your alarm going off, but your siren is knackered.
Posted 4th Nov 2011 at 17:06
Rix13
Thought it was, is it a matter of unlocking with the fob to stop it?
Posted 4th Nov 2011 at 17:11
Yup, you need to unset the alarm.
Posted 4th Nov 2011 at 17:12
Rix13
trip to dealership then Crazy
Posted 4th Nov 2011 at 17:28
atterz
New alarm siren mate, or unplug the siren and dont set the alarm, just use the key!
owain wrote:
Posted 4th Nov 2011 at 17:31
But if the alarm's already set...?
Rix13
couldnt care about the alarm, yer if i put the fuse in it sets the alarm and the fob hasnt had a battery in for a while so prob useless now, also someone bust it so i cant put battery in. is there a way of disabling the alarm without interfering with the radio and central locking?
Posted 4th Nov 2011 at 17:36
