displaying posts 26 to 50 of 74
Pages (3): 1 [2] 3
Author Subject: steam supercharger?
jimmyhackers wrote:
asking them to make sure a water resevoir other than the radiator is topped up is beyond most (motorists) ability.
Have you built it yet?
Posted 8th Nov 2011 at 13:40
jimmyhackers
yes granted that thing is a tiny tesla turbine with a cheap dynamo on it however that dynao is far to small for what the unit can actually output. the turbine design is more efficient than older steam engines. and my boiler isnt quite like a conventional boiler.
its going to be a coil of 1/4" copper wrapped around and braised to the exhaust then heat taped for max heat absorbtion. this should be far more efficient than old style boilers
as for my cat...........well i would tell you but i dont know where its gone Razz
bmw are going down the peltier seenbeck route, which as ive said is slightly different and you get electrical power not mechanical. they seem to of overcomplicated the matter with water cooling one side of the plate and made it rather expesive.
Posted 8th Nov 2011 at 15:41
Really? You think the surface area and thermal conductance of a thin, tubular, mild steel exhaust, which has a smooth inner bore and minimal contact with the exhaust plume, is going to be better than those conventional boilers with miles of thin-wall, small bore copper tube right in the heat path?
OK then. Have fun.
Posted 8th Nov 2011 at 15:45
Pwned!
Posted 8th Nov 2011 at 15:54
Can people please stop giving arguments as to why this is clearly a bad idea please, I want to see it done.
Posted 8th Nov 2011 at 16:35
It might work better with a copper exhaust pipe with the coil soldered directly to it, that would get you some better heat transfer at any rate, I think it's going to be a srtuggle to get the kind of heat required for steam of sufficient pressure/volume to run a turbine though. That and the fact that on a short journey from cold or long periods sat at ldle you effectively won't have a charger at all, as you will have to thrash it to build up a head of steam powerful enough to turn the compressor, f*ck that for a laugh.
Posted 8th Nov 2011 at 18:33
jimmyhackers
i was going to braise the coil to the exhaust with silver solder to aid heat transfer aswell as wrap the exhaust and the coil so more heat is trapped inside. im not doubting a boiler may be more refined, but id argue there heat source isnt as intense as that from exhaust gases.
yes putting the copper pipe inside the pipe and directly in the flow of the gases would be more efficient but means a lot more fabrication. :S
im experimenting at the moment as i said on my 1.4 im not expecting this to turn my car into a beast. its a proof of concept. the next step after getting it to run the tiny telsa would be stepping up the dynamo on the turbine to see what kind of of kw it can generate from that i can deduce a rough bhp figure.
and see wether its worth investing in a larger turbine or making the exhaust more efficient or to call it a day on bhp gains and convert it to make tea
Posted 8th Nov 2011 at 22:59
Do it already.
Posted 9th Nov 2011 at 08:05
m306
any progress on this? its been nearly a month...
supercharged China gti6 - Thu 16th Sep 1999 - sold
2010 megane rs250
Posted 7th Dec 2011 at 23:12
Post #35
He's probably changed his mind and moved onto another revolutionary idea lke using the power of his own farts to raise manifold pressure and enable a faster burn on the combustion cycle...
Posted 7th Dec 2011 at 23:23
Post #36
I think he's enthusiasm ran out of steam.
I'll get my coat.
Posted 7th Dec 2011 at 23:27
Post #37
Tumbleweed...
Posted 7th Dec 2011 at 23:30
m306
Post #38
no offence intended but why is he allowed to use the technical forums? is it for the comedy factor? because it definitely isnt for technical knowledge Dunno
ive even seen advice on brakes along the lines of "to measure for disk warping put on a flat surface"???? wtf happened to using a dial gauge like everyone else?
sorry ive gone off topic but i just cant understand this guy.
would love to see if the steam charger works though Thumbs up
2010 megane rs250
Posted 7th Dec 2011 at 23:37
Post #39
Because he's the only guy who still posts in the technical forums.
Posted 7th Dec 2011 at 23:39
m306
Post #40
fair point.
what happened to the sig? its been toned down
2010 megane rs250
Posted 7th Dec 2011 at 23:40
Post #41
It's a newfangled Derren Brown subconscious method of making people hate me, first demonstrated in this thread.
Posted 7th Dec 2011 at 23:43
Post #42
Cos he paid his membership fee? Instant forum expert status is garanteed Smile
Posted 7th Dec 2011 at 23:45
Post #43
Only on this forum could people post up in General, get shot down and told to pay so they can post in Technical, only to be abused for posting in Technical having paid.
Anyway who cares, where's my f*cking group buy on steam superchargers?
Posted 7th Dec 2011 at 23:47
m306
Post #44
forum expert you say? maybe i should ask him where to put my stickers Wink Laugh my ass off
2010 megane rs250
m306
Post #45
yeah but i thought common sense says you don't answer technical questions and give advice if you don't know what you're talking about?? i don't have the greatest mechanical knowledge therefor i wouldn't tell someone how to do an engine swap (for example). so he shouldn't give incorrect advice on brakes.
but please do continue with the steam charger quest Thumbs up
2010 megane rs250
Posted 7th Dec 2011 at 23:51
Post #46
You're a nob Razz
Posted 8th Dec 2011 at 00:01
Post #47
Oh crap, I definitely did not get *that* memo. That's me out then.
Post #48
daveyboy wrote:
You're a nob
IT'S WORKING!!!
Posted 8th Dec 2011 at 00:02
Post #49
owain wrote:
daveyboy wrote:
You're a nob
IT WORKED
Posted 8th Dec 2011 at 00:04
Post #50
If I did'nt think it would make you cry, I'd tell you exactly where to put yer bloody stickers! LOL
Pages (3): 1 [2] 3
