Author Subject: V6 engine and ecu
yadam
Hi my Ecu I got with my engine is ment to be decoded. How could I tell if it's not, the engine is turning but not firing if u spray in a Littel easy start it will fire on that but that's it. The car is pumping fuel up to the rail so i changed the injection loom thinking it was that but still no joy .Could any body help
Posted 10th Nov 2011 at 12:47
simonjames
is fuel pump going when turned over? could a crank sensor ? multi relay ?
MY EBAY ITEMS
07943066306
Posted 10th Nov 2011 at 13:20
yadam
Do u mean the engine or car fuel pump the car pumps fuel up the rail nd if u press the valve on the rail fuel will spray out
Posted 11th Nov 2011 at 09:32
simonjames
Any idea if it spraying whilst being turned over? not sure about v6 but 6 engine the crank sensor/multi relay allow the injector to open so if crank sensor not working or relay not sending signal injector wont spray (or sparks wont spark)
Easiest thing to do is check if you have spark at the plugs (i'd say you have as it does fire up) and fuel out the injectors (not just at the rail) i had 1 once that had both spark and fuel, timing was spot on trned out to be an ect sensor flooding the plug with fuel
MY EBAY ITEMS
07943066306
Posted 11th Nov 2011 at 10:33
it works exactly like the gti6 system, though does have two double relays
Posted 11th Nov 2011 at 12:04
yadam
Ok there is no fuel goin thro the injectors so I check the sensors
Posted 11th Nov 2011 at 13:39
simonjames
Yes i'd say 1 of double relays has failed and therefore not giving the ecu signal to switch the injectors
MY EBAY ITEMS
07943066306
Posted 11th Nov 2011 at 14:19
relay doesnt give signals, ecu does Wink
Posted 11th Nov 2011 at 15:29
simonjames
ecu gives the signal after the relay has
MY EBAY ITEMS
07943066306
Posted 11th Nov 2011 at 17:44
its a relay....
Posted 11th Nov 2011 at 17:54
simonjames
crank sensor send yay or nay the relay
relay passes yay or nay to ecu
ecu sends yay or nay to components .........................
MY EBAY ITEMS
07943066306
Posted 11th Nov 2011 at 18:47
no, crank sensor is connected to the ecu and the ecu only.
a relay does not send signals, its activated by the ecu to power up injectors/coilpack/fuel pump.
Posted 11th Nov 2011 at 18:57
simonjames
i thought it went through the relay to the ecu, doesnt matter anyway they are all linked, if crank goes on stop relay doesnt get yay from ecu
relay powering up inj/coil/fuel is what i meant by sending the signal
MY EBAY ITEMS
07943066306
Posted 11th Nov 2011 at 19:17
