Team Diesel
| Author | Subject: Trailing arm shaft |
cornish_pug
Regular Location: Marazion Registered: 18 Dec 2009 Posts: 368 Status: Offline |
Removed one of the trailing arms today and the shaft is "fubar" so i'll need a new one. I'm wondering when buying a new shaft does it need to be stepped like the original or can it be the same diameter along it's full length like some are on ebay.________________________________________ Team Diesel |
doesn't matter, the bearing surfaces are the same.got a pic of both your shafts? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cornish_pug
welshpug! wrote: doesn't matter, the bearing surfaces are the same. got a pic of both your shafts? Not yet, only got the off side removed atm the outside bearing had nearly completely disintergrated. Tomorrow i'll be taking off the near side, which is the side that is still square to the beam tube. If the shaft on that side is good i'll just get the bearings. I'll put some pics up tomorrow. ________________________________________ Team Diesel |
That's how most are these days, did my brothers beam last weekend and even though the bearings and seals were intact on one side the shaft was still worn out.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cornish_pug
You would think that the shafts would be case hardened for the prices they charge. ________________________________________ Team Diesel |
they are.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cornish_pug
welshpug! wrote: they are. Not bad for 10 years wear I suppose. ________________________________________ Team Diesel |
