Author Subject: gti vacuum pump
JWP EFi
Turbo Legend!
will the brake servo still function if i do away with vacuum pump? and take vacuum off inlet with a 1 way valve
reason i ask is, i need to strip my pump to make way for a phase sensor setup so i can run cosworth management
its either that or make up a toothed wheel for the inlet pulley.
Posted 18th Nov 2011 at 15:12
there's a cam position sensor on there already Huh?
Posted 18th Nov 2011 at 15:22
JWP EFi
Turbo Legend!
i know that
its no where near compatible with cossie ecu, iirc gti6 phase sensor has 3 pins, cossie only has 2
Anyway, what about vac pump??!
Posted 18th Nov 2011 at 15:30
JWP EFi
Turbo Legend!
didnt explain very well, basically im planning to put new phase sensor gubbins inside vac pump, not do away with it
all together
Posted 18th Nov 2011 at 15:32
